Hi all,
I've used photorec to recover quite a few files on a disk which has lost it's partition table.
But none of those were .java files of which there should be tons. I see .java is not to be selected in the "File opt" list.
Several people on this forum said they had recovered .java files but I'd like to double check, considering time spent, will photorec find java classes with .java extention?
Great little tool btw.
Erwin
.java files
Re: .java files
Well i think that you have to select java extension in the "file opt" list.
