Search in specific folder for specific filetype? Topic is solved
MjWoNeR
#1 Post by MjWoNeR »
Is it possible to set Photorec to only search in the desktop folder and recycle bin and recover only.TXT files?
If yes how do I do it?
Re: Search in specific folder for specific filetype?
Unfortunately it's not possible to search a single folder.
Only free space or while disk.
You can go to File Opt and press s to deselct all file types.
Then you can select only those file types where you want to recover.
MjWoNeR
#3 Post by MjWoNeR »
Thanks for the reply. :)
I managed to recover one of the two .txt files. The other one was overwritten. Better than nothing.
