Gparted lost most of my FAT32 partition
PostWarranty
#1 Post by PostWarranty »
Background:
I've got a 1TB disk on a GPT partition table with several partitions. I was attempting to move a 400GB FAT32 partition (labeled STORAGE) to the left to claim some free space, I then attempted to expand it to 500GB using GParted. When the process finished I was left with only 1 folder (only about 70MB of data) on that partition, the rest just disappeared.
After the initial analysis with testdisk I am greeted with a number of messages telling me that my cylinders not the correct size and that I have an incorrect number of sectors per track. That's where things get sketchy. I'm not sure how to correctly aline the cylinders (if I understand correctly)
Below is the text of the log (wouldn't let me attach the file), any clarification would be appreciated
Fri Mar 8 19:19:05 2013
OS: Linux, kernel 3.5.0-17-generic (#28-Ubuntu SMP Tue Oct 9 19:31:23 UTC 2012) x86_64
Compiler: GCC 4.7
Compilation date: 2012-10-01T13:00:04
ext2fs lib: 1.42.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco 1953525168 sectors
/dev/sdb: size 1953525168 sectors
/dev/sdb: user_max 1953525168 sectors
/dev/sdb: dco 1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000524AS, S/N:5VP9T3XA, FW:JC4B
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000524AS, S/N:6VPESSCV, FW:JC4B
Disk /dev/sdc - 8004 MB / 7633 MiB - CHS 1020 247 62, sector size=512 - SanDisk Cruzer, FW:1.14
Disk /dev/sdb - 1000 GB / 931 GiB - ST31000524AS
Partition table type: EFI GPT
NTFS at 0/233/18
heads/cylinder 135 (NTFS) != 255 (HD)
sect/track 4 (NTFS) != 63 (HD)
filesystem size 204832
mft_lcn 8852
mftmirr_lcn 257
MS Data 14696 219527 204832
NTFS, 104 MB / 100 MiB
HFS magic value at 49/72/19
part_size 2598944898
Mac HFS 791739 2599736636 2598944898
HFS, 1330 GB / 1239 GiB
This partition ends after the disk limits. (start=791739, size=2598944898, end=2599736636, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 1331 GB / 1239 GiB)
P MS Data 14696 219527 204832
1 P MS Data 14696 219527 204832
NTFS at 0/0/9
NTFS at 12/191/28
NTFS at 12325/0/1
Info: size boot_sector 210049867, partition 210049875
FAT32 at 25400/76/21
Info: size boot_sector 976375808, partition 976375808
FAT1 : 96-119267
FAT2 : 119268-238439
start_rootdir : 862184 root cluster : 9748
Data : 238440-976375783
sectors : 976375808
cluster_size : 64
no_of_cluster : 15252146 (2 - 15252147)
fat_length 119172 calculated 119158
Warning: Incorrect number of heads/cylinder 135 (NTFS) != 255 (HD)
Warning: Incorrect number of sectors per track 4 (NTFS) != 63 (HD)
1 * HPFS - NTFS 0 0 9 12 191 27 204832 [System Reserved]
2 P HPFS - NTFS 12 191 28 12324 209 45 197793432 [Windows 7 Enterprise (1)]
3 P HPFS - NTFS 12325 0 1 25399 254 63 210049875 [copy of E]
Warning: Incorrect number of sectors per track 32 (FAT) != 63 (HD)
4 P FAT32 25400 76 21 86176 225 1 976375808 [STORAGE]
Computes LBA from CHS for Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121602 255 63
search_vista_part: 1
NTFS at 0/0/9
mft_lcn 8852
mftmirr_lcn 257
NTFS at 12/191/28
filesystem size 197793432
mft_lcn 7753986
mftmirr_lcn 253
NTFS, 101 GB / 94 GiB
NTFS at 12325/0/1
filesystem size 210049867
mftmirr_lcn 6555520
HPFS - NTFS 12325 0 1 25399 254 55 210049867 [copy of E]
NTFS, 107 GB / 100 GiB
FAT32 at 25400/0/1
FAT1 : 158-119330
FAT2 : 119331-238503
start_rootdir : 239592 root cluster : 19
Data : 238504-976382503
sectors : 976382505
cluster_size : 64
no_of_cluster : 15252250 (2 - 15252251)
fat_length 119173 calculated 119159
FAT differs, FAT sectors=0-16/119173
FAT32 at 25400/0/1
FAT32 LBA 25400 0 1 86176 254 63 976382505 [NO NAME]
FAT32, 499 GB / 465 GiB
recover_EXT2: s_block_group_nr=0/38, s_mnt_count=21/34, s_blocks_per_group=32768, s_inodes_per_group=8016
recover_EXT2: s_blocks_count 1250048
recover_EXT2: part_size 10000384
Linux 119593 130 26 120216 1 41 10000384
EXT4 Large file Sparse superblock Recover, 5120 MB / 4883 MiB
Linux Swap 120216 34 11 120340 141 41 1998832
SWAP2 version 1, 1023 MB / 975 MiB
P HPFS - NTFS 12325 0 1 25399 254 55 210049867 [copy of E]
L FAT32 LBA 25400 0 1 86176 254 63 976382505 [NO NAME]
L Linux 119593 130 26 120216 1 41 10000384
L Linux Swap 120216 34 11 120340 141 41 1998832
dir_partition inode=0
FAT: cluster=19(0x13), pos=408290592
3 P HPFS - NTFS 12325 0 1 25399 254 55 210049867 [copy of E]
4 E extended LBA 25399 254 56 121601 254 63 1545485138
5 L FAT32 LBA 25400 0 1 86176 254 63 976382505 [NO NAME]
6 L Linux 119593 130 26 120216 1 41 10000384
7 L Linux Swap 120216 34 11 120340 141 41 1998832
NTFS at 0/0/9
mft_lcn 8852
mftmirr_lcn 257
BAD_RS LBA=69640 126
HPFS - NTFS 4 85 26 17 21 44 204832
NTFS at 12/191/28
mft_lcn 7753986
mftmirr_lcn 253
NTFS at 12325/0/1
mftmirr_lcn 6555520
FAT32 at 25400/0/1
FAT1 : 158-119330
sectors : 976382505
cluster_size : 64
FAT32 at 25400/0/1
FAT32 at 25400/0/7
FAT1 : 158-119330
sectors : 976382505
cluster_size : 64
FAT differs, FAT sectors=64-80/119173
heads/cylinder 0 (FAT) != 255 (HD)
sect/track 0 (FAT) != 63 (HD)
FAT32 at 25400/0/7
FAT32 LBA 25400 0 1 25399 254 63 0
FAT found using backup sector!, 0 B
Partition not added.
FAT1 : 96-119267
sectors : 976375808
cluster_size : 64
FAT32 LBA 25400 76 21 86176 225 1 976375808 [STORAGE]
FAT32 at 25400/76/27
FAT1 : 96-119267
sectors : 976375808
cluster_size : 64
FAT32 LBA 25400 76 21 86176 225 1 976375808 [NO NAME]
FAT found using backup sector!, 499 GB / 465 GiB
BAD_RS LBA=3593158734 4689538
FAT12 223663 200 40 419194 116 48 3141200232
This partition ends after the disk limits. (start=3593158734, size=3141200232, end=6734358965, disk end=1953536130)
recover_EXT2: s_block_group_nr=0/47, s_mnt_count=12/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 1572608
recover_EXT2: part_size 12580864
Linux 32063 38 40 32846 69 55 12580864
EXT4 Large file Sparse superblock Recover, 6441 MB / 6143 MiB
Linux 32954 96 39 33737 127 54 12580864
Linux 32987 198 44 33770 229 59 12580864
recover_EXT2: s_block_group_nr=0/47, s_mnt_count=5/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 33005 94 50 33788 126 2 12580864
Linux 33017 155 35 33800 186 50 12580864
Linux 33021 45 49 33804 77 1 12580864
file_pread(5,16,buffer,749303808(46642/1/16)) read err: Input/output error
file_pread(5,1,buffer,749303808(46642/1/16)) read err: Input/output error
BAD_RS LBA=812549567 6047
FAT16 <32M 50578 222 12 51237 245 41 10588314
BAD_RS LBA=2143339093 5312168
FAT16 <32M 133416 175 29 133417 21 36 6371
This partition ends after the disk limits. (start=2143339093, size=6371, end=2143345463, disk end=1953536130)
BAD_RS LBA=5252963560 11488441
FAT32 326981 218 62 482699 92 25 2501601696
This partition ends after the disk limits. (start=5252963560, size=2501601696, end=7754565255, disk end=1953536130)
HFS+ magic value at 74000/239/32
part_size 15728640
HFS 74000 239 32 74980 0 28 15728640
HFS+, 8053 MB / 7680 MiB
recover_EXT2: s_block_group_nr=0/59, s_mnt_count=4/30, s_blocks_per_group=32768, s_inodes_per_group=8160
recover_EXT2: s_blocks_count 1966079
recover_EXT2: part_size 15728632
Linux 74057 7 63 75036 23 51 15728632
EXT4 Large file Sparse superblock Recover, 8053 MB / 7679 MiB
recover_EXT2: s_block_group_nr=0/186, s_mnt_count=13/30, s_blocks_per_group=32768, s_inodes_per_group=8160
recover_EXT2: s_blocks_count 6103296
recover_EXT2: part_size 48826368
Linux 74058 110 37 77097 187 18 48826368
EXT4 Large file Sparse superblock Recover, 24 GB / 23 GiB
Linux 74058 208 7 77098 29 51 48826368
Linux 74062 0 51 77101 77 32 48826368
recover_EXT2: s_block_group_nr=0/186, s_mnt_count=11/30, s_blocks_per_group=32768, s_inodes_per_group=8160
Linux 74064 0 1 77103 76 45 48826368
recover_EXT2: s_block_group_nr=0/186, s_mnt_count=3/30, s_blocks_per_group=32768, s_inodes_per_group=8160
Linux 74067 253 43 77107 75 24 48826368
Linux 74069 166 18 77108 242 62 48826368
NTFS at 74980/32/61
filesystem size 179879936
mft_lcn 4
mftmirr_lcn 11242495
HPFS - NTFS 74980 32 61 86177 35 2 179879936 [Bckups]
NTFS, 92 GB / 85 GiB
Linux 75334 102 33 78373 179 14 48826368
recover_EXT2: s_block_group_nr=0/38, s_mnt_count=24/34, s_blocks_per_group=32768, s_inodes_per_group=8016
Linux 119871 205 15 120494 76 30 10000384
recover_EXT2: s_block_group_nr=0/38, s_mnt_count=16/34, s_blocks_per_group=32768, s_inodes_per_group=8016
Linux 119877 8 4 120499 134 19 10000384
recover_EXT2: s_block_group_nr=0/38, s_mnt_count=10/34, s_blocks_per_group=32768, s_inodes_per_group=8016
Linux 119885 211 7 120508 82 22 10000384
NTFS at 121601/25/24
sect/track 14 (NTFS) != 63 (HD)
filesystem size 1953314816
mftmirr_lcn 2
HPFS - NTFS 12 223 20 121601 25 24 1953314816
NTFS found using backup sector!, 1000 GB / 931 GiB
The harddisk (1000 GB / 931 GiB) seems too small! (< 3970 GB / 3697 GiB)
get_geometry_from_list_part_aux head=255 nbr=5
FAT: cluster=9748(0x2614), pos=408917992
9750 -rwxr-xr-x 0 0 4096 26-Nov-2011 14:46 ._.Trashes
10365 drwxr-xr-x 0 0 0 17-Feb-2013 11:32 SALVAGE
9749 drwxr-xr-x 0 0 0 26-Nov-2011 14:46 .Trashes
X 2 drwxr-xr-x 0 0 0 3-Mar-2013 00:27 _SEVEN~1
9755 drwxr-xr-x 0 0 0 26-Nov-2011 14:46 .Spotlight-V100
9771 drwxr-xr-x 0 0 0 26-Nov-2011 15:00 $RECYCLE.BIN
10065 drwxr-xr-x 0 0 0 16-May-2012 23:06 .TemporaryItems
1894375 -rwxr-xr-x 0 0 4096 21-Jan-2012 15:27 ._Tumblr-2.0.bar
4122028 -rwxr-xr-x 0 0 5064969 27-Feb-2012 18:57 Words_With_Friends_4.70.bar
1894538 -rwxr-xr-x 0 0 4096 26-Mar-2012 11:15 ._Words_With_Friends_4.70.bar
10262 -rwxr-xr-x 0 0 4096 16-May-2012 23:06 ._.TemporaryItems
NTFS at 0/0/9
NTFS at 12/191/28
NTFS at 12325/0/1
FAT1 : 96-119267
sectors : 976375808
cluster_size : 64
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : No
