Adobe PageMaker 7.0 (.pmd file) Topic is solved
kariz
#1 Post by kariz »
Hello Everyone.
I'm new here but not to testdisk pack.
Anyway, kindly seeking help to recover .pmd files for a friend in distress. Is it possible with photorec? so far cannot find the option to check.
thanks.
Re: Adobe PageMaker 7.0 (.pmd file)
Can you send me several pmd file samples ? I will see if it's possible to add this file format to PhotoRec.
kariz
#3 Post by kariz »
Thank you for your reply, i can do that tomorrow, 27th. I assume that i will reply to your email with the attachments.
Regards
Addendum: I have posted the .pmd files as requested to: grenier@cgsecurity.org
Thnx
To close the subject, the pmd files have been recovered with a .p65 extension, the extension for Adobe PageMaker 6.5.
The extension isn't really important.
