Can someone tell me how to fix partition boundaries and MBR
Deleted User 3588
#1 Post by Deleted User 3588 »
My notebook used to have this /dev/sdb (1TB HDD, with C: on the first 292.97 GB, i.e. /dev/sdb1). It was encrypted and got corrupt.
Then I installed OS on /dev/sda (500GB disk, my C: drive is sda1, 270 GB) and ran TestDisk on decrypted /dev/sdb (it maybe caused more damage, but there's no way to read anything if one doesn't decrypt the disk). Now the partition (sdb1) is reported as RAW. The rest (600GB) was unallocated, by the way, so there's nothing behind sdb1 until the end of HDD.
I can't understand the output. I'd like to know if it's possible - and how - to recover /dev/sdb1 (it's NTFS) so that I can mount it. I tried to use another "extracting" tool and to read chunks of data from /dev/sdb1 and it did come up with some files and images (but few), so I think maybe there's a way to extract more.
In Windows disk manager I can see the first partition on /dev/sdb1, it's 292.97 GB, while the rest is 638.54 GB.
Here in output I don't quite understand what to do.
Fri Jul 12 22:34:16 2013
TestDisk 6.14-WIP, Data Recovery Utility, May 2013
Compilation date: 2013-07-09T07:38:49
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=270467620864
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MK5061GSY, S/N:X 71BKF1BX, FW:MC10
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM 014-1EJ164, S/N:3W08R2JS, FW:SM11
Disk /dev/sdb - 1000 GB / 931 GiB - ST1000LM 014-1EJ164
New options :
Dump : No
Align partition: Yes
Expert mode : No
1 * HPFS - NTFS 0 32 33 38244 194 14 614400048
Not an exFAT boot sector.
Invalid NTFS or EXFAT boot
BAD_RS LBA=2371767682 1447940
file_pread(5,1,buffer,2371767682(147635/181/5)) lseek err Invalid argument
HPFS - NTFS 147635 181 5 279654 157 59 2120883778
This partition ends after the disk limits. (start=2371767682, size=2120883778, end=197684163, disk end=1953525168)
BAD_RS LBA=770812005 15577822
file_pread(5,3,buffer,770812005(315330/45/17)) lseek err Invalid argument
file_pread(5,1,buffer,770812005(315330/45/17)) lseek err Invalid argument
FAT12 315330 45 17 399968 17 24 1359707714
This partition ends after the disk limits. (start=770812005, size=1359707714, end=2130519718, disk end=1953525168)
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 3289 GB / 3063 GiB)
