Disk structure - bad back up boot sector
LiquidFusion
#1 Post by LiquidFusion »
Working on last drive = 750 GB
1. Wasn't sure of CHS 254 vs 255. Went with 255 and did Deep Search earlier (4 hrs) for 750 GB HDD.
2. Bad Backup Boot Sector - cant fix this. Any help welcome. Thank you.
Tue Jul 16 13:30:49 2013
TestDisk 6.14-WIP, Data Recovery Utility, May 2013
OS: Windows XP SP3
Compilation date: 2013-06-24T18:54:26
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=300090728448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=300090728448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=32547432960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=469869085184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=467549553152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=30063398400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=105662882304
filewin32_getfilesize(\\.\M:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\M:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\M:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\V:)=194426233344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=750161954304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=750153729024
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD50 00AAKB-00H8A, FW:05.0
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD50 00AAKB-00H8A, FW:05.0
Disk /dev/sdc - 300 GB / 279 GiB - CHS 38764 240 63, sector size=512 - Maxtor 6L300R0, S/N:364C523158444853, FW:BAJ41G20
Disk /dev/sdd - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Maxtor OneTouch, S/N:02b9100028cf4011, FW:0121
Disk /dev/sde - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Maxtor OneTouch, S/N:02b9100001364211, FW:0121
Disk /dev/sde - 750 GB / 698 GiB - Maxtor OneTouch
Analyse Disk /dev/sde - 750 GB / 698 GiB - CHS 91201 255 63
NTFS at 0/1/1
file_pread(8,4096,buffer,79(0/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(8,1,buffer,3789(0/60/10)) ReadFile Data error (cyclic redundancy check).
NTFS: Can't read MFT
1 * HPFS - NTFS 0 1 1 91201 254 63 1465160067
NTFS at 0/1/1
filesystem size 1465160067
mft_lcn 2
mftmirr_lcn 48
file_pread(8,4095,buffer,80(0/1/18)) ReadFile Data error (cyclic redundancy check).
NTFS, blocksize=4096, 750 GB / 698 GiB
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
file_pread(8,1,buffer,1465160129(91201/254/63)) lseek err Invalid argument
filesystem size 1465160067 1
sectors_per_cluster 8 0
mft_lcn 2 0
mftmirr_lcn 48 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 16, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 2
ntfs_find_mft: mftmirr_lcn 48
mft_lcn 2
mftmirr_lcn 48
ntfs_boot_sector
NTFS at 0/1/1
mft_lcn 2 0
mftmirr_lcn 48 0
Status: OK
Status: Bad
