Hello!
I have a Problem. Upon switching off my hardddrive (in an external case - Sharkoon) from my settopbox and switching it back on on my PC (same external case) it was not recognized by my PC anymore. I was prompted to format the drive - which I of course did not do. I used TestDisks Step by step Tutorial but I got the message "Can't open filesystem. Filesystem seems damaged. I also want to point out that label of the drive should not be F4 2TB but something like F2 1000GB. The former label was the last drive which I had inserted in my external case before I put in the now defunct drive. At the time Auslogic DiskDefrag was running and it was listing the F4 2TB drive and did not switch to the F2 1000GB. I added the three screenshots and the log file. The harddisk is a Samsung HD103SI 1TB disk.
Thanks for any help you can provide.
Sincerely, Alex S.
Logfile:
Sun Apr 1 14:11:01 2012
OS: Windows Vista (6002) SP2
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=150035496960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=25774080
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202241024
filewin32_getfilesize(\\.\X:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\X:) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\X:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=92681535488
file_pread(4,1,buffer,488408129(30401/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,1953536129(121601/254/63)) lseek err Invalid argument
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - FUJITSU MHX2250BT, S/N:2020202020202020324b3030375432384e365647, FW:0000000B
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Generic External, S/N:S1VSJ90S705229, FW:2.10
Drive D: - 25 MB / 24 MiB - CHS 6 64 32, sector size=2048 - HUAWEI Mass Storage, FW:2.31
Disk /dev/sdc - 1000 GB / 931 GiB - Generic External
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/1/1
1 P HPFS - NTFS 0 1 1 121600 254 63 1953520002 [F4 2TB]
$MFTMirr location mismatch or first 4 records are fragmented. Run chkdsk.
Failed to load $MFTMirr: Input/Output error.
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121602 255 63
search_vista_part: 1
NTFS at 0/1/1
filesystem size 1953520002
mftmirr_lcn 122095000
NTFS, 1000 GB / 931 GiB
file_pread(5,8,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,1953525311(121601/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525439(121601/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525567(121601/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525695(121601/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* HPFS - NTFS 0 1 1 121600 254 63 1953520002 [F4 2TB]
Not an exFAT boot sector.
1 * HPFS - NTFS 0 1 1 121600 254 63 1953520002 [F4 2TB]
NTFS at 0/1/1
Filesystem seems damaged. 1TB drive
- 3.JPG (55.76 KiB) Viewed 65371 times
- 2.JPG (54.76 KiB) Viewed 65371 times
- 1.JPG (36.14 KiB) Viewed 65371 times
Re: Filesystem seems damaged. 1TB drive
F4 2TB as label looks strange?
Doesn't match somehow?
Can you have a try to diagnose your boot sector?
Start TestDisk.
Confirm through until you see the menu Analyse.
Confirm at Boot with enter also.
Infos will follow.
Until yet don't use write or repair NTFS. It's always better not to change anything, if you're not sure.
Start TestDisk.
Infos will follow.
Thank you for the quick answer. I've added a screenshot of the result. What I am worried about is that TestDisk seems to think that the disk size is 2TB or am I misinterpreting the "1953520002" value? Could it be that the MBR or something else was transfered from my 2TB disk to my 1TB disk and that is the result that the drive is not accessible anymore?
Thanks for any additional help!
Sincerelly,
Alex S.
Sincerelly,
Alex S.
- 5.JPG (46.11 KiB) Viewed 65365 times
- 4.JPG (58.04 KiB) Viewed 65365 times
1953520002 is the total amount of sectors.
You can watch the size of your partition at the bottom of the screen.
The boot sector displayes it.
Example;
Might be possible that you see your data and you can copy them to another intact disk or partition.
Otherwise you'll need datarecovery software.
Example;
Please test the menu Advanced / Undelete.* HPFS - NTFS 0 1 1 121600 254 63 1953520002 [F4 2TB]
The only message I get is "Can't open filesystem. Filesystem seems damaged." It is the same if I choose 'List' or 'Undelete'.
In 'Boot' 'Repair MFT' I get the message "MFT and MFT Mirror are bad. Failed to repair them."
Should I create an image with 'Image Creation' before I try anyting else?
Might PhotoRec be able to recreate any data?
Thanks,
Alex S.
Thanks,
Alex S.
- 6.jpg (49.2 KiB) Viewed 65307 times
PhotoRec woud be able to recover data.
But it doesn't keep file names nor directories.
TestDisk Image Creation only creates an image to work with.
If you want to restore it, you probably have to use dd from a Linux LiveCD.
Some information about working with images;
http://www.cgsecurity.org/wiki/Media_Image
What happens if PhotoRec finds more than one file with the same name? Does it rename the file to someting like _0001.extension or is there an error message displayed? There were/are a lot of files with the same name on the drive.
Would a communication in german be easier?
Thanks,
Alex S.
Thanks,
Alex S.
Names created by PhotoRec look like this;
f14040728
PhotoRec renames each file.
So you wouldn't get any error message.
Please use TestDisk 6.14.
Infos;
Currently I see no reason to change languages.
It would be necessary to create another thread and it makes this one obsolete.
I've had a look for another copy of a FAT32-partition in your testdisk.log-file, but I didn't get any clue
Like in this example;
http://www.cgsecurity.org/wiki/Data_Rec ... to_recover
f14040728
Infos;
The drive is formatted as NTFS. It was partitoned under Windows XP. I tried 6.14 but got the same results. Logfile attached.
Thanks,
Alex S.
Fri Apr 6 16:28:16 2012
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
Compilation date: 2012-03-25T21:26:26
NTFS at 0/1/1
NTFS at 0/1/1
NTFS at 0/1/1
NTFS at 0/1/1
Thanks,
Alex S.
NTFS at 0/1/1
NTFS at 0/1/1
NTFS at 0/1/1
NTFS at 0/1/1
PhotoRec did manage to reconstruct nearly all of my data on the disk - but it mixed up several .mpg files. A lot of them have beginning, middle and/or endings of different files. Also it has merged and split up a lot of files. So if there is another way or chance to repair the drive any help would be appreciated.
Thanks,
Alex S.
Thanks,
Alex S.
