Partition not visible, missing 0xAA55
hellward
#1 Post by hellward »
Partition is not visible. Partition Magic shows only unallocated space.
HPFS - NTFS 60800 254 63 99044 253 58 614389793
TestDisk message:
Problem:
Full log:
Fri Aug 23 15:03:18 2013
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=60011642880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=60011642880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=26847281664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=148079715840
filewin32_getfilesize(\\.\F:) GetFileSize err Niepoprawna funkcja.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Niepoprawna funkcja.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=30005789184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=29997563904
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEVT-80A0RT0, FW:01.01A01
Disk /dev/sdb - 60 GB / 55 GiB - CHS 7296 255 63, sector size=512 - FUJITSU MHT2060BH
Disk /dev/sda - 500 GB / 465 GiB - WDC WD5000BEVT-80A0RT0
NTFS at 0/1/1
NTFS at 3264/0/1
get_geometry_from_list_part_aux head=255 nbr=8
get_geometry_from_list_part_aux head=8 nbr=3
get_geometry_from_list_part_aux head=16 nbr=3
get_geometry_from_list_part_aux head=32 nbr=3
get_geometry_from_list_part_aux head=64 nbr=3
get_geometry_from_list_part_aux head=240 nbr=3
1 * HPFS - NTFS 0 1 1 3263 254 63 52436097
NTFS, blocksize=4096, 26 GB / 25 GiB
2 P HPFS - NTFS 3264 0 1 21266 254 63 289218195 [stuff]
NTFS, blocksize=4096, 148 GB / 137 GiB
3 E extended LBA 21267 0 1 60800 254 63 635113710
X extended 22557 0 1 60800 254 63 614389860
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/1/1
NTFS at 3264/0/1
test_logical:
NTFS at 0/1/1
filesystem size 52436097
mftmirr_lcn 3277256
NTFS at 3264/0/1
filesystem size 289218195
mft_lcn 4
mftmirr_lcn 524288
Linux Swap 21267 1 1 21528 21 55 4194280
SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
NTFS at 21529/1/1
filesystem size 16514757
mftmirr_lcn 1032172
HPFS - NTFS 21529 1 1 22556 254 63 16514757 [SWAP]
NTFS, blocksize=4096, 8455 MB / 8063 MiB
NTFS at 60800/254/63
filesystem size 614389793
mft_lcn 4
mftmirr_lcn 524288
HPFS - NTFS 22557 1 5 60800 254 63 614389793
NTFS found using backup sector, blocksize=4096, 314 GB / 292 GiB
mft_lcn 4
mftmirr_lcn 524288
NTFS, blocksize=4096, 314 GB / 292 GiB
This partition ends after the disk limits. (start=976768064, size=614389793, end=1591157856, disk end=976773168)
file_pread(4,3,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(4,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(4,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(4,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(4,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(4,8,buffer,976773280(60801/82/50)) lseek err Invalid argument
file_pread(4,1,buffer,976773280(60801/82/50)) lseek err Invalid argument
file_pread(4,8,buffer,976773408(60801/84/52)) lseek err Invalid argument
file_pread(4,8,buffer,976773536(60801/86/54)) lseek err Invalid argument
file_pread(4,8,buffer,976773664(60801/88/56)) lseek err Invalid argument
file_pread(4,8,buffer,976773792(60801/90/58)) lseek err Invalid argument
file_pread(4,8,buffer,976773920(60801/92/60)) lseek err Invalid argument
file_pread(4,8,buffer,976774048(60801/94/62)) lseek err Invalid argument
file_pread(4,8,buffer,976774176(60801/97/1)) lseek err Invalid argument
file_pread(4,8,buffer,976774304(60801/99/3)) lseek err Invalid argument
file_pread(4,8,buffer,976774432(60801/101/5)) lseek err Invalid argument
file_pread(4,8,buffer,976774560(60801/103/7)) lseek err Invalid argument
file_pread(4,8,buffer,976774688(60801/105/9)) lseek err Invalid argument
file_pread(4,8,buffer,976774816(60801/107/11)) lseek err Invalid argument
file_pread(4,8,buffer,976774944(60801/109/13)) lseek err Invalid argument
file_pread(4,8,buffer,976775072(60801/111/15)) lseek err Invalid argument
file_pread(4,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(4,1,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(4,14,buffer,976775169(60801/112/49)) lseek err Invalid argument
file_pread(4,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(4,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(4,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(4,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(4,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
The harddisk (500 GB / 465 GiB) seems too small! (< 814 GB / 758 GiB)
get_geometry_from_list_part_aux head=255 nbr=7
L Linux Swap 21267 1 1 21528 254 63 4208967
SWAP2 version 1, pagesize=4096, 2154 MB / 2055 MiB
L HPFS - NTFS 21529 1 1 22556 254 63 16514757 [SWAP]
L HPFS - NTFS 22557 1 5 60800 254 63 614389793
add_ext_part_i386: max
add_ext_part_i386: min
5 L Linux Swap 21267 1 1 21528 254 63 4208967
6 L HPFS - NTFS 21529 1 1 22556 254 63 16514757 [SWAP]
7 L HPFS - NTFS 22557 1 5 60800 254 63 614389793
Failed to open $MFT/$BITMAP: No such file or directory.
ntfs_mft_load(): Failed.
Failed to load $MFT: No such file or directory.
Failed to startup volume: No such file or directory.
NTFS at 0/1/1
mftmirr_lcn 3277256
NTFS at 3263/254/63
mftmirr_lcn 3277256
NTFS found using backup sector, blocksize=4096, 26 GB / 25 GiB
NTFS at 3264/0/1
mft_lcn 4
mftmirr_lcn 524288
recover_EXT2: s_block_group_nr=0/74, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8144
recover_EXT2: s_blocks_count 2441406
recover_EXT2: part_size 19531248
Linux 7460 64 29 8676 4 16 19531248
ext4 blocksize=4096 Large file Sparse superblock Recover, 9999 MB / 9536 MiB
Linux 7460 161 62 8676 101 49 19531248
Linux 7462 74 37 8678 14 24 19531248
Linux 7463 112 10 8679 51 60 19531248
Linux 7466 127 22 8682 67 9 19531248
Linux 7470 82 37 8686 22 24 19531248
Linux 7471 120 10 8687 59 60 19531248
Linux 7472 0 1 8687 194 51 19531248
Linux 7472 190 15 8688 130 2 19531248
Linux 7473 32 48 8688 227 35 19531248
NTFS at 21529/1/1
mftmirr_lcn 1032172
mft_lcn 4
mftmirr_lcn 524288
mft_lcn 4
mftmirr_lcn 524288
get_geometry_from_list_part_aux head=8 nbr=5
get_geometry_from_list_part_aux head=16 nbr=4
get_geometry_from_list_part_aux head=240 nbr=4
Linux 7460 64 29 8676 12 40 19531776
ext4 blocksize=4096 Large file Sparse superblock Recover, 10000 MB / 9537 MiB
Linux 7460 161 62 8676 110 10 19531776
Linux 7462 74 37 8678 22 48 19531776
Linux 7463 112 10 8679 60 21 19531776
Linux 7466 127 22 8682 75 33 19531776
Linux 7470 82 37 8686 30 48 19531776
Linux 7471 120 10 8687 68 21 19531776
Linux 7472 0 1 8687 254 63 19535040
ext4 blocksize=4096 Large file Sparse superblock Recover, 10001 MB / 9538 MiB
Linux 7472 190 15 8688 138 26 19531776
Linux 7473 32 48 8688 235 59 19531776
P Linux Swap 21267 1 1 21528 254 63 4208967
P HPFS - NTFS 21529 1 1 22556 254 63 16514757 [SWAP]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 23-Aug-2013 01:38 .
5 dr-xr-xr-x 0 0 0 23-Aug-2013 01:38 ..
27710 dr-xr-xr-x 0 0 0 20-Aug-2013 20:41 Counter-Strike 1.6
1968 dr-xr-xr-x 0 0 0 26-Jun-2011 00:53 DV
34650 dr-xr-xr-x 0 0 0 23-Aug-2013 13:19 Downloads
128 dr-xr-xr-x 0 0 0 23-Aug-2013 01:38 Nowy folder
30 dr-xr-xr-x 0 0 0 11-Jun-2013 20:58 RECYCLER
27 dr-xr-xr-x 0 0 0 6-Aug-2010 22:14 System Volume Information
93 dr-xr-xr-x 0 0 0 21-Aug-2013 15:08 filmy
127 dr-xr-xr-x 0 0 0 23-Aug-2013 01:42 foty
1547 dr-xr-xr-x 0 0 0 19-Feb-2013 14:59 music
64 dr-xr-xr-x 0 0 0 7-Nov-2012 18:42 ubuntu
5 dr-xr-xr-x 0 0 0 22-Aug-2013 16:36 .
5 dr-xr-xr-x 0 0 0 22-Aug-2013 16:36 ..
3421 dr-xr-xr-x 0 0 0 22-Nov-2012 22:55 Documents and Settings
24474 dr-xr-xr-x 0 0 0 20-Mar-2012 02:05 MSOCache
44168 dr-xr-xr-x 0 0 0 22-Aug-2013 16:36 Pobieranie
3887 dr-xr-xr-x 0 0 0 22-Aug-2013 20:27 Program Files
11247 dr-xr-xr-x 0 0 0 11-Jun-2013 20:58 RECYCLER
3419 dr-xr-xr-x 0 0 0 10-Mar-2012 16:17 System Volume Information
28 dr-xr-xr-x 0 0 0 22-Aug-2013 16:28 WINDOWS
81945 dr-xr-xr-x 0 0 0 2-Jul-2013 13:46 eclipse
55010 dr-xr-xr-x 0 0 0 12-Aug-2013 15:45 php5
29007 dr-xr-xr-x 0 0 0 27-Oct-2012 13:30 temp
23406 dr-xr-xr-x 0 0 0 31-Jul-2013 11:59 wamp
7294 -r--r--r-- 0 0 0 10-Mar-2012 16:02 AUTOEXEC.BAT
1997 -r--r--r-- 0 0 4952 22-Jul-2001 02:13 Bootfont.bin
7293 -r--r--r-- 0 0 0 10-Mar-2012 16:02 CONFIG.SYS
7295 -r--r--r-- 0 0 0 10-Mar-2012 16:02 IO.SYS
7296 -r--r--r-- 0 0 0 10-Mar-2012 16:02 MSDOS.SYS
3384 -r--r--r-- 0 0 47564 3-Aug-2004 22:38 NTDETECT.COM
24370 -r--r--r-- 0 0 827 7-Apr-2013 13:14 VirtualDJ Local Database v6.xml
3413 -r--r--r-- 0 0 238 23-Aug-2013 14:52 boot.ini
3380 -r--r--r-- 0 0 251152 11-Mar-2012 02:36 ntldr
54410 -r--r--r-- 0 0 2145386496 23-Aug-2013 15:00 pagefile.sys
54410 -r--r--r-- 0 0 0 23-Aug-2013 15:00 pagefile.sys
114845 -r--r--r-- 0 0 132151 7-Nov-2012 18:42 wubildr
114941 -r--r--r-- 0 0 8192 7-Nov-2012 18:42 wubildr.mbr
Not an exFAT boot sector.
Change partition type:
2 E extended LBA 22557 0 1 60800 254 63 614389860
5 L HPFS - NTFS 22557 1 5 60800 254 63 614389793
2 E extended LBA 3264 0 1 60800 254 63 924331905
write_all_log_i386: CHS: 22557/0/1,lba=362378205
New options :
Dump : No
Expert mode : Yes
A new copy of MBR code has been written.
You have to reboot for the change to take effect.
NTFS at 0/1/1
NTFS at 3264/0/1
Help much appreciated.
Re: Partition not visible, missing 0xAA55
If TestDisk has found all your partitions, choose to write the new partition table (Analyse, Quick Search, Write, confirm, Quit)
