I have used TestDisk to Analyze the disk with this messages:
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
Disk /dev/sdb - 8010 MB / 7639 MiB - CHS 973 255 63
Invalid FAT boot sector
1 P FAT32 LBA 32 162 4 881 246 25 13644499
Bad relative sector.
2 P Linux 849 84 56 973 213 8 2000140
Warning: Bad ending cylinder (CHS and LBA don't match)
>[Quick Search] [ Backup ]
Try to locate partition
>L Linux 849 84 56 973 213 4 2000136
Enter: to continue
EXT3 Sparse superblock Recover, 1024 MB / 976 MiB
1 E extended 849 0 1 973 213 4 2005483
5 L Linux 849 84 56 973 213 4 2000136
[ Quit ] >[Deeper Search] [ Write ] [Extd Part]
Try to find more partitions
I tried to repair the FAT partition with Advanced options and this is the result:
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (Second part of boot code) are not identical.
>[ Quit ] [Rebuild BS] [ Dump ]
Return to Advanced menu
Can't find cluster size
>[Ok]
Thanks in advance.
