recover info select .wd2 file
greenetech
#1 Post by greenetech »
I need to recover a .wd2 info select database file and am not good enough with programming to figure out how to correctly add the custom extension. Has anyone done this? The raw recovery utilities I am using are recovering the other files but now the .wd2.
Re: recover info select .wd2 file
If needed, please send a a zip archive with 3 small wd2 files. I will see what I can do.
greenetech
#3 Post by greenetech »
Thank you!!!
test1.zip
.wd2 files
(1.61 KiB) Downloaded 773 times
Create a photorec.sig file with
wd2 0 "ISW WD2.00U"
Please tell me if it works as expected
greenetech
#5 Post by greenetech »
Thank You. I will try it. Is it ok for me to use notepad to create the file with just:
wd2 0 "ISW WD2.00U"
#6 Post by cgrenier »
Yes, it should work.
greenetech
#7 Post by greenetech »
No it did not work. I will go ahead and post the photorec.sig file I used. Can you make sure it is correct?
photorec.zip
(161 Bytes) Downloaded 745 times
#8 Post by cgrenier »
Remove the line "CODE: SELECT ALL"
