Hi. I have an old MAXTOR 120GB HDD i use to store all my photos (!). recently, for some reason, it became unaccessible from windows (saying "the disk structure is corrupted or unreadable"). disk management shows the HD as healthy and online but as RAW instead of NTFS. Testdisk identifies the partition but can't read the files and deep search resulted in "the harddisk seems too small". log file attached.
help will be very appreciated...
Damaged Filesystem or not ?
Re: Damaged Filesystem or not ?
Probably something went wrong?log file attached.
Can you either copy and paste the content or zip your log file and upload it?
Mon Apr 02 21:23:07 2012
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
Compiler: GCC 4.7, MinGW 3.11
Compilation date: Mar 25 2012 21:26:32
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=122941242880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=80025223168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396289024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=122935002624
Disk \\.\PhysicalDrive0 - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 122 GB / 114 GiB - CHS 14946 255 63, sector size=512
Drive C: - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512
Drive D: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Drive E: - 122 GB / 114 GiB - CHS 14945 255 63, sector size=512
Partition table type: None
Analyse Drive E: - 122 GB / 114 GiB - CHS 14945 255 63
NTFS at 0/0/1
filesystem size 240107427
mftmirr_lcn 15006714
NTFS at 0/0/1
P NTFS 0 0 1 14945 253 63 240107427
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
NTFS at 0/0/1
NTFS, 122 GB / 114 GiB
Write isn't available because the partition table type "None" has been selected.
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
LVM magic value at 6583/90/24
NTFS at 14945/222/61
filesystem size 728497474
mft_lcn 770047
mftmirr_lcn 14986112
NTFS part_offset=122934001152, part_size=372990706688, sector_size=512
mft_lcn 770047
NTFS: Can't read MFT
NTFS 14945 222 61 60292 189 58 728497474
NTFS, 372 GB / 347 GiB
This partition ends after the disk limits. (start=240105471, size=728497474, end=968602944, disk end=240107427)
file_win32_pread(108,11,buffer,240107417(14945/253/54)) read err: read after end of file
file_win32_pread(108,11,buffer,240107419(14945/253/56)) read err: read after end of file
file_win32_pread(108,11,buffer,240107425(14945/253/62)) read err: read after end of file
file_win32_pread(108,8,buffer,240107420(14945/253/57)) read err: read after end of file
file_win32_pread(108,3,buffer,240107426(14945/253/63)) read err: read after end of file
file_win32_pread(108,8,buffer,240107424(14945/253/61)) read err: read after end of file
file_win32_pread(108,8,buffer,240107421(14945/253/58)) read err: read after end of file
file_win32_pread(108,8,buffer,240107423(14945/253/60)) read err: read after end of file
file_win32_pread(108,8,buffer,240107426(14945/253/63)) read err: read after end of file
file_win32_pread(108,6,buffer,240107422(14945/253/59)) read err: read after end of file
file_win32_pread(108,6,buffer,240107424(14945/253/61)) read err: read after end of file
file_win32_pread(108,6,buffer,240107426(14945/253/63)) read err: read after end of file
NTFS at 14945/253/63
NTFS found using backup sector!, 122 GB / 114 GiB
The harddisk (122 GB / 114 GiB) seems too small! (< 495 GB / 461 GiB)
New options :
Dump : No
Align partition: Yes
Expert mode : No
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
NTFS at 0/0/1
mft_lcn 770047
mft_lcn 770047
New options :
Dump : No
Expert mode : No
TestDidsk should be executed as Administrator using rigght click and "run as Administrator" in case.
In case, please use TestDisk the 32 bit executable.
Don't select Drive but Disk if you get to the disk selection in TestDisk!
Please repeat your diagnose.
It looks like that your file system is damaged.
Check it, if your partition is found pressing p.
