Hi, inserted my 3tb disk in my new NAS. I'm new to this so I didn't know that the disk will be formatted. Now I'm trying to get my data back and downloaded Parted Magic. After running GParted it says that the disk is unallocated.
Then I run testdisk und analyzed it, then the failure "bad relative sector no partition is bootable" appeared. After running Quick Search, which didn't find the partition I run Deeper Search. Now theres at the beginning of the search
HPFS - NTFS 2 14 13 45600 40 8 732533504 [Volume]
Is this my partition? Can i stop deeper search? Am I on the right way to get my data back?
Hope for help!
Accidently formatted, possible to recover files
Re: Accidently formatted, possible to recover files
Select this partition and press 'p'. If you can see your files, it's your partition
If you have problems, please post the whole testdisk.log file
