ExFAT formated to Mac OS Extended
brunobarcelos
#1 Post by brunobarcelos »
I was doing a backup from my MacBook Air to a ExFAT 500GB external HDD but just when was done, accidentally I chose the external drive to be formatted to Mac OS Extended. After same seconds, when I realized what I did, I unpluged the drive from the Macbook before the process was over.
Now when I plug the disk it doesn't show on the desktop, but I can see it on Disk Utility. And I was able to recover some files using PhotoRec. But I want the folder structures and the filenames.
How can I recover the original ExFAT partition?
Re: ExFAT formated to Mac OS Extended
Run TestDisk, Advanced, select this partition, use Type to force the type to exFAT if necessary, Boot.
If available, choose BackupBS and confirm.
brunobarcelos
#3 Post by brunobarcelos »
But just the HFS+ partition is available.
It's why you have to force the type to exFAT
