OSX Lion not booting after shutdown during bootcamp process
datamstr
#1 Post by datamstr »
Hello, I started a Bootcamp installation on my OSX Lion Mac Pro. Once I realized that I could only use Windows 7, I had to hold off on the installation until I located my Windows 7 disk. I had set the Bootcamp partition size to 100 GB on a 500 GB Drive. I left the computer in that state for a week or so. Due to threatning weather, I shutdown the computer and after that, OSX Lion no longer boots.
I talked to Apple Support and so far it is still not working. I was able to boot using the recovery partition "Disk Utility -> First Aid -> Repair Disk". When I ran Repair Disk there were some errors reported and repaired, then OSX still not booting.
After some research, I came across TestDisk. I attempted to repair the system, but after a few repair attempts the drive has now become read only and I can't figure out how to reverse that.
Media is opened in read-only.
Disk /dev/rdisk2 - 500 GB / 465 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 500 GB / 465 GiB - 976773168 sectors (RO)
hdr_size=92
hdr_lba_self=976773167
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=976773135
hdr_entries=128
hdr_entsz=128
Trying alternate GPT
 1 P EFI System                    40     409639     409600 [EFI System Partition]
 2 P Mac HFS                   409640  975503591  975093952 [Untitled]
 3 P Mac Boot               975503592  976773127    1269536 [Recovery HD]
Re: OSX Lion not booting after shutdown during bootcamp proc
The disk is probably in read-only mode because a partition is mounted.
Start a Terminal and run the command "mount". Try to identify any partition from /dev/disk2 that is listed and run "sudo umount directory_name" where directory_name is the directory listed in mount output.
Once it's done, run again TestDisk. The disk shouldn't be in read-only mode anymore. After Analyse, Quick Search, select the last HFS partition, use Type to change its type to Mac Boot, on next screen, you will have
Choose Write, confirm, Quit
datamstr
#3 Post by datamstr »
Chris, I was able to unmout directories and the disk became writable. After setting the last HFS partition to Mac Boot, the next screen shows P HFS+ along with other partition types listed. At that point I could not choose Write,confirm,Quit so I just pressed Enter again to select HFS+. Then the last partition showed P Mac Boot. I pressed Enter, then Write, Confirm, Quit. Then I rebooted and when the computer booted the screen was flickering off and on sort of randomly. I pressed he Command key and my login prompt appeared for the OSX I installed on Disk1.
I ran TestDisk again and the Disk 2 last partition was not listed as Mac Boot, it was HFS.
I will try again.
Next step?
Thanks,
David
datamstr
#4 Post by datamstr »
Also, forgot to mention that Disk Utility shows the Disk 2 partition type as GPT now and the Recovery HD partition is not listed anymore.
I will email the testdisk.log to you.
Thanks,
David
datamstr
#5 Post by datamstr »
When I power up the computer while holding the Option key, I select the "untitled" volume. The Apple logo appears the the spinning wheel runs for a few minutes. Then the circle with the line through it appears.
Thanks,
David
#6 Post by cgrenier »
Still waiting for the new testdisk.log file...
