Wrote down most of what I saw on screen so hope this info can help someone help me fix my problem. I would be so greatful!
Dell computer has 2 drives:
Create a new log YES
>80 - 250GB / 232 GiB. ---->highlighted this one and entered
>81 - 320GB / 298 GiB
INTEL and entered
Disk 80 - 250GB / 232 GiB
CHS 30394 255 63 - sector size =512
ANALYZE
1 P Dell Utility. 0. 1. 1. 4. 254. 63. 80262
2 *HPFS-NTFS 5. 0. 1 30392. 254. 63 488183220
QUICK SEARCH
>* FAT16 > 32M. 0. 1. 1. 4. 254. 63. 80262 [Dell Utility]
>P HPFS-NTFS. 5. 0. 1 30392 254. 63. 488183220
FAT16, blocks=2048,41MB/39MiB
Clicked "P" and could see files and directories
Then highlighted NTFS
NTFS,bocksize =4096,249GB/232GB
Then DEEPER SEARCH revealed..
FAT16 > 32MB 0. 1. 1. 4. 254. 63. 80262. [Dell Utility]
HPFS-NTFS 5 0. 1. 30392 254. 60. 488183217
Said The harddisk (250GB/232GB) seems too small! (<2155GB/2007GiB)
CheckFAT: can't read FAT boot sector
Invalid boot sector
OD FAT16 > 32M. 141687. 107. 12. 262042. 124. 23. 1933504158
[CONTINUE]
989GB/921GB
After changing Dell Utility to P and NTFS to * and p for files
WRITE then QUIT
Disk 80 - 250GB / 232 GB - CHS 30394 255 63
1 P FAT16 > 32M. 0. 1. 1. 4. 254. 63. 80262
FAT: 16
Cluster_size: 4. 4
Reserved: 1. 1
Total. Sect: 80262. 80262
Fat_length: 79. 79
Dir entries: 512. 512
Extrapolated boot sector and current boot sector are different
WRITE
REBUILD BOOT
List and showed files
NOTE: then proceeded to do the same steps on the NTFS partition and think I should not have because now can't see files like previosly could.
DISK8 80 - 250GB / 232GiB - CHS 30394 255. 63
2 * HPFS-NTFS 5. 0. 1. 30392. 254. 63. 488183220
Status: OK
Status: OK
Sectors are identical
REBUILD BS
Filesystem size: 488183220 488183217
Sectors_per_cluster: 8. 8
mft_lcn: 786432. 770020
mftmirr_lcn: 30511451. 19150805
Clusters_per_mft_record: -10. -10
Clusters_per_index_record: 1. 1
NOTE: I noticed the numbers were different, unlike the previos partition ???
REPAIR MFT
NOTE: Tried to list files again but this time it says something like filesystem not present. I guess I screwed my system up worse than it was to start with as in I believe I was getting the Blue Screen with code 0x0000007B even when trying to boot in safe mode of WinXP. I was able to get into my recovery console and could see all my files but it would not allow me to copy these files to my new external USB HD so I could then reformat my internal drives and reinstall everything from scratch and then move data files back once I had a clean system.
Please help!! Hope I didn't ruin my filesystem beyond recovery and someone can help me get my MFT pointing to the files again. Thanks in advance for help!
