Accidently Write MBR Code to WD Essential 2TB
attraction88
#1 Post by attraction88 »
i need a little help here as im lost
I have an external Western Digital 2TB hard disk for storing backup files. After my external enclosure fails which screw up my partitions, i took out the hard disk and mount it on a 3rd party enclosure. I accidentally write MBR using Test disk on a Window XP. After Rebooting, each tme i plug into my Window XP, it automatically restarts the window. So, i used another computer wihich is Window 7, which it can detect. Now, the computer detects as 7 partitions, 3 which is unallocated, and 4 is fine, but still cant appear on my computer.
I have run the analyze for quick scan and deeper scan, but nothing came out.
all i wanted in to recover some photo that i have collected over the years. i tried to run PhotoRec, and so far all the files has unknows file extensions.
attraction88
Re: Accidently Write MBR Code to WD Essential 2TB
#2 Post by attraction88 »
Attached is the pictures that i have taken after the scan.
this is the screen after the deeper search
partitions found after the scan
#3 Post by cgrenier »
If the actual partition table content triggers a bug in Windows, you can run TestDisk and choose Delete. Don't select the wrong disk!
What is the result after Deeper Scan ?
attraction88
#4 Post by attraction88 »
This is the results of the quick scan and deeper scan. Can you please help to identify what seems to be the problem here.
Sun Feb 12 19:11:59 2006
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=31347179520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=48562020864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=104857600
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - Hitachi HTS541680J9SA00, S/N:2020202020204253323234304753414a57374531, FW:SB2OC7BP
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20 EARS-00MVWB0, S/N:152D20337A0C
Disk /dev/sdb - 2000 GB / 1863 GiB - WDC WD20 EARS-00MVWB0
check_part_i386 1 type A8: no test
check_part_i386 2 type EC: no test
check_part_i386 3 type 2C: no test
1 P Darwin UFS 35774 39 56 53413 34 48 283370213
2 P Sys=EC 102092 162 2 155337 80 10 855375768
3 P Sys=2C 171272 248 50 264358 175 30 1495421972
BAD_RS LBA=1780175524 13210907
file_pread(5,3,buffer,1780175524(378160/38/27)) lseek err Invalid argument
file_pread(5,1,buffer,1780175524(378160/38/27)) lseek err Invalid argument
FAT16 >32M 378160 38 27 574591 220 17 3155675472
This partition ends after the disk limits. (start=1780175524, size=3155675472, end=640883699, disk end=3907029168)
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,14,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(5,3,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(5,3,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(5,8,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907033087(243201/143/14)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4726 GB / 4401 GiB)
These are the pictures after the scan
after the quick scan and deeper scan, are are no partitions.
deeper scan
deeper scan
first quick scan
first quick scan
#5 Post by cgrenier »
What extensions do you got with PhotoRec ?
attraction88
#6 Post by attraction88 »
Sorry, but what extension do you mean? Im kinda lost..
Thanks
