Help disk Problem
pedjuama
HELP disk problem
#1 Post by pedjuama »
I have a disk problem, it need format, i did it to access and recover the old info later, but now the disk runs ok but i can recover the old info.
I use Getdataback but it seems there are a MFT problem
When i use Testdisk in the first step the disk appear 3 times
i try to use testdisk in some of the options but i cant write in the last step.
Can someone help me ?
Re: Help disk Problem
/dev/sdb is ok. Can you post the content of testdisk.log file after trying Advanced, Boot, List, RebuildBS, List ?
