File System died following install of Linux with Vista
sam1984
#1 Post by sam1984 »
Hi everyone,
I'm a novice at hard drives, and recently tried to install Linux in a dual boot arrangement with Windows Vista. The install seemed to go fine, Linux works, but I could no longer boot into Windows. I've tried various methods to try and fix the boot system, which may have made it worse. Now taking that disk out and plugging it in with a USB adaptor to my laptop I have run testdisk.
The results are just crazy! Loads of partitions to pick from and I don't know where to go from here. Here's the log file of me doing a scan and deep scan. Any help would be greatly appreciated!
Thanks in advance,
Sam
Thu Sep 19 18:47:59 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=160035766272
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=59629896704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2256142336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=258291712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=73995264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=34365219840
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - TOSHIBA MK3265GSXN, S/N:X09NC4KOT, FW:GH10
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST350062 0AS, S/N:152D20337A0C
Drive E: - 2256 MB / 2151 MiB - CHS 537 64 32, sector size=2048 - HL-DT-ST DVDRAM GT30N, S/N:M3ZAA1G1019, FW:TN08
Drive F: - 258 MB / 246 MiB - CHS 61 64 32, sector size=2048
Disk /dev/sdb - 500 GB / 465 GiB - ST350062 0AS
FAT16 at 0/1/1
Info: size boot_sector 144522, partition 144522
FAT1 : 1-141
FAT2 : 142-282
start_rootdir : 283
Data : 315-144518
sectors : 144522
cluster_size : 4
no_of_cluster : 36051 (2 - 36052)
fat_length 141 calculated 141
FAT32 at 9/0/1
Info: size boot_sector 67119570, partition 67119570
FAT1 : 32-8229
FAT2 : 8230-16427
start_rootdir : 16428 root cluster : 2
Data : 16428-67119531
sectors : 67119570
cluster_size : 64
no_of_cluster : 1048486 (2 - 1048487)
fat_length 8198 calculated 8192
FAT differs, FAT sectors=0-16/8198
1 * FAT16 >32M 0 1 1 8 254 63 144522 [DellUtility]
FAT16, blocksize=2048, 73 MB / 70 MiB
2 P FAT32 LBA 9 0 1 4186 254 63 67119570 [ Unlabeled]
FAT32, blocksize=32768, 34 GB / 32 GiB
3 P Linux 41041 52 36 60279 37 46 309057536
ext4 blocksize=4096 Large file Sparse superblock, 158 GB / 147 GiB
4 E extended LBA 60279 70 15 60801 47 30 8384497
5 L Linux Swap 60279 70 16 60801 47 30 8384496
SWAP2 version 1, pagesize=4096, 4292 MB / 4093 MiB
FAT16 at 0/1/1
FAT1 : 1-141
FAT2 : 142-282
start_rootdir : 283
Data : 315-144518
sectors : 144522
cluster_size : 4
FAT32 at 9/0/1
FAT1 : 32-8229
FAT2 : 8230-16427
sectors : 67119570
cluster_size : 64
FAT16 at 0/1/1
FAT1 : 1-141
FAT2 : 142-282
start_rootdir : 283
Data : 315-144518
sectors : 144522
cluster_size : 4
FAT16 at 0/1/1
FAT32 at 9/0/1
FAT1 : 32-8229
FAT2 : 8230-16427
sectors : 67119570
cluster_size : 64
FAT32 at 9/0/1
recover_EXT2: s_block_group_nr=0/1178, s_mnt_count=20/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 38632192
recover_EXT2: part_size 309057536
file_pread(5,2,buffer,976773167(60801/80/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,976773168(60801/81/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,8,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(5,8,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(5,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(5,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(5,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(5,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
L Linux Swap 60279 70 16 60801 47 46 8384512
SWAP2 version 1, pagesize=4096, 4292 MB / 4094 MiB
add_ext_part_i386: max
4 E extended LBA 60279 37 47 60801 80 15 8388608
5 L Linux Swap 60279 70 16 60801 47 46 8384512
Failed to load the complete runlist for $MFT/$DATA. Bug or corrupt $MFT. Run chkdsk.
highest_vcn = 0x768f, last_vcn - 1 = 0x106cf
ntfs_mft_load(): Failed.
$MFT has invalid magic.
FAT16 at 0/1/1
FAT1 : 1-141
FAT2 : 142-282
start_rootdir : 283
Data : 315-144518
sectors : 144522
cluster_size : 4
FAT16 at 0/1/1
FAT32 at 9/0/1
FAT1 : 32-8229
FAT2 : 8230-16427
sectors : 67119570
cluster_size : 64
FAT32 at 9/0/1
FAT32 at 9/0/7
FAT1 : 32-8229
FAT2 : 8230-16427
sectors : 67119570
cluster_size : 64
FAT32 at 9/0/7
NTFS at 9/13/5
filesystem size 31457280
mftmirr_lcn 1966079
HPFS - NTFS 9 13 5 1967 44 61 31457280 [RECOVERY]
NTFS, blocksize=4096, 16 GB / 15 GiB
NTFS at 1967/44/61
mftmirr_lcn 1966079
NTFS found using backup sector, blocksize=4096, 16 GB / 15 GiB
NTFS at 1967/44/62
filesystem size 627723849
mftmirr_lcn 59073023
HPFS - NTFS 1967 44 62 41041 45 37 627723849 [OS]
NTFS, blocksize=4096, 321 GB / 299 GiB
NTFS at 13472/241/17
filesystem size 945168384
NTFS part_offset=110818754048, part_size=483926212608, sector_size=512
block_group_nr 1
recover_EXT2: s_block_group_nr=1/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 158 GB / 147 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_block_group_nr=0/1178, s_mnt_count=11/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 50463 136 42 69701 121 52 309057536
ext4 blocksize=4096 Large file Sparse superblock Recover, 158 GB / 147 GiB
This partition ends after the disk limits. (start=810696704, size=309057536, end=1119754239, disk end=976773168)
Linux 50464 0 1 69701 240 11 309057536
This partition ends after the disk limits. (start=810704160, size=309057536, end=1119761695, disk end=976773168)
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/1178, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
NTFS at 60801/47/46
HPFS - NTFS 1967 44 62 60801 47 46 945168384 [OS]
NTFS found using backup sector, blocksize=4096, 483 GB / 450 GiB
file_pread(5,2,buffer,976773183(60801/81/16)) lseek err Invalid argument
NTFS at 1967/44/61
mftmirr_lcn 1966079
The harddisk (500 GB / 465 GiB) seems too small! (< 573 GB / 533 GiB)
HPFS - NTFS 1967 44 61 3925 76 54 31457280
HPFS - NTFS 1967 44 62 41041 52 35 627724288 [OS]
Not an exFAT boot sector.
NTFS Volume is dirty.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 3-Aug-2013 16:36 .
5 dr-xr-xr-x 0 0 0 3-Aug-2013 16:36 ..
11442 dr-xr-xr-x 0 0 0 11-Feb-2010 23:00 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 24-Feb-2009 03:35 Program Files
84 dr-xr-xr-x 0 0 0 19-Jan-2008 08:45 ProgramData
11439 dr-xr-xr-x 0 0 0 23-Feb-2009 18:30 System Volume Information
11279 dr-xr-xr-x 0 0 0 24-Feb-2009 03:49 Tools
105 dr-xr-xr-x 0 0 0 19-Jan-2008 08:45 Users
142 dr-xr-xr-x 0 0 0 24-Feb-2009 03:34 Windows
11323 dr-xr-xr-x 0 0 0 24-Feb-2009 03:35 dell
2288 dr-xr-xr-x 0 0 0 29-Jan-2008 17:53 sources
dir_partition inode=2
2 drwxr-xr-x 0 0 4096 18-Aug-2013 21:19 .
2 drwxr-xr-x 0 0 4096 18-Aug-2013 21:19 ..
11 drwx------ 0 0 16384 3-Aug-2013 22:30 lost+found
4849665 drwxr-xr-x 0 0 12288 8-Sep-2013 11:29 etc
4456449 drwxr-xr-x 0 0 4096 8-Sep-2013 11:22 media
5767169 drwxr-xr-x 0 0 4096 8-Sep-2013 11:29 var
4587521 drwxr-xr-x 0 0 4096 5-Aug-2013 18:47 bin
6291457 drwxr-xr-x 0 0 4096 5-Aug-2013 18:53 boot
1048577 drwxr-xr-x 0 0 4096 13-Feb-2013 22:10 dev
4980737 drwxr-xr-x 0 0 4096 3-Aug-2013 22:37 home
5111809 drwxr-xr-x 0 0 4096 5-Aug-2013 18:49 lib
8912897 drwxr-xr-x 0 0 4096 18-Aug-2013 21:31 mnt
524289 drwxr-xr-x 0 0 4096 6-Aug-2013 14:00 opt
5242881 drwxr-xr-x 0 0 4096 19-Apr-2012 10:32 proc
1179649 drwx------ 0 0 4096 8-Sep-2013 10:37 root
3670017 drwxr-xr-x 0 0 4096 3-Aug-2013 22:40 run
7077889 drwxr-xr-x 0 0 4096 8-Sep-2013 10:52 sbin
3145729 drwxr-xr-x 0 0 4096 5-Mar-2012 13:48 selinux
1572865 drwxr-xr-x 0 0 4096 13-Feb-2013 22:07 srv
3276801 drwxr-xr-x 0 0 4096 14-Apr-2012 10:26 sys
6553601 drwxrwxrwt 0 0 4096 8-Sep-2013 11:29 tmp
5505025 drwxr-xr-x 0 0 4096 13-Feb-2013 22:07 usr
15 lrwxrwxrwx 0 0 33 5-Aug-2013 18:51 initrd.img
12 lrwxrwxrwx 0 0 29 5-Aug-2013 18:51 vmlinuz
131073 drwxr-xr-x 0 0 4096 3-Aug-2013 22:37 cdrom
1310721 drwxr-xr-x 0 0 4096 18-Aug-2013 21:19 boot-sav
13 lrwxrwxrwx 0 0 32 3-Aug-2013 22:41 initrd.img.old
14 lrwxrwxrwx 0 0 29 3-Aug-2013 22:41 vmlinuz.old
Invalid partition structure.
abdkh
Re: File System died following install of Linux with Vista
#2 Post by abdkh »
hi friend ,
I do have the same problem 6 months ago !!
till this day I have no resolve
I'd visited Ubuntu forum and I read every think and apply their prescriptions to my hard sick disk ,
and here we are < no solution .
now i am trying to save some files and pictures after those experts of Linux destroy any possible chance to
recover bad sectors which made by Linux overwriting file sys , as computer tech store told me wile he returned back the hard disk to me , saying : sorry no one can fix it !
Lito
#3 Post by Lito »
Windows Vista uses something called BCD to boot.
This website offers a commercial as well as a free (limited) version of a BCD manager
called Easy BCD:
http://neosmart.net/EasyBCD/
As you can see, in that page, there is a warning that Easy BCD cannot fix a computer that does not boot.
But they offer a download of a CD image, for you to burn and create EasyRE to fix it.
To burn the image you could use ImgBurn, Nero or any other programme of your choice.
You will have to return your HDD to its original place, and then boot the PC with your copy of
EasyRE CD in the tray.
May be you could do a bit more research about the problem in this place (one of many):
http://www.vistax64.com/
It is a forum about Windows Vista.
If your data is important clone your HDD, before trying to fix it.
Alternatively, if you can list your files with TestDisk, copy them to anoher HDD.
Lets hope this is of help.
Best of luck
