Need help partition recovery
yeakyau
1TB hard disk found alot partition
#1 Post by yeakyau »
Dear SIr /Madam,
I had one 1 TB hard disk cavair green actually uses to do testing on windows 8 / windows 7 etc..
last few day i used to backup my data transfer into this hard disk, suddenly it corrupted after using a ide / sata converter.
now i doing a deep search found alot of partition.. just wondering which should I choose i'm confusing when i press P to list the file in the partition it not found.. and i accident quite it have to scan all over again and again...
yeakyau
#2 Post by yeakyau »
HI,
need help how to recovery my partition.
I have 2 partition one is windows 8 C: . D: my backup document.
I just wonder which partition should i choose..
below is my print screen.
after perform a search i press P list to list out the directory it doesn't show any file or folder,
however my data parition should be around 600GB, and this hard disk has been used to do testing install windows.
HERE IS MY LOG FILE
ri Sep 27 00:39:48 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=266616176640
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=266721034240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=466759974912
Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512 - WDC WD1002FAEX-00Z3A0, S/N:2020202057202d44435754413652333832393230, FW:05.01D05
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EARS-003BB1, S/N:2020202057202d44435756414a35383936333938, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10EARS-003BB1
NTFS at 0/1/1
filesystem size 976751937
mftmirr_lcn 2
HPFS - NTFS 0 1 1 60799 254 63 976751937
NTFS at 71798/12/23
heads/cylinder 240 (NTFS) != 255 (HD)
filesystem size 6393856
mftmirr_lcn 2
HPFS - NTFS 71798 12 23 72196 12 8 6393856 [New Volume]
NTFS, blocksize=4096, 3273 MB / 3122 MiB
NTFS at 111358/107/46
filesystem size 787314688
mftmirr_lcn 2
HPFS - NTFS 111358 107 46 160366 126 16 787314688 [New Volume]
NTFS, blocksize=4096, 403 GB / 375 GiB
This partition ends after the disk limits. (start=1788973056, size=787314688, end=2576287743, disk end=1953525168)
NTFS at 121599/254/63
mftmirr_lcn 2
HPFS - NTFS 60800 1 1 121599 254 63 976751937
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
mftmirr_lcn 2
file_pread(5,4096,buffer,1959795455(121991/159/24)) lseek err Invalid argument
file_pread(5,1,buffer,1959795455(121991/159/24)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 121599 254 63 182399 253 62 976751937
This partition ends after the disk limits. (start=1953503999, size=976751937, end=2930255935, disk end=1953525168)
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1500 GB / 1397 GiB)
get_geometry_from_list_part_aux head=16 nbr=4
get_geometry_from_list_part_aux head=32 nbr=4
get_geometry_from_list_part_aux head=64 nbr=4
get_geometry_from_list_part_aux head=128 nbr=4
get_geometry_from_list_part_aux head=240 nbr=4
* HPFS - NTFS 0 1 1 60799 254 63 976751937
interface_load
1 * HPFS - NTFS 0 1 1 60799 254 63 976751937
Re: 1TB hard disk found alot partition
#3 Post by cgrenier »
There are CHS (Cylinder, Head, Sector) for the beginning and end of the partition. The last number is its size in sector.
The partition listed in the first screenshot is using the first half of the disk.
You need to try to list the content of each partition.
yeakyau
Re: Need help partition recovery
#4 Post by yeakyau »
it is using "p" to list out the content? =)
yeakyau
#5 Post by yeakyau »
May i know why it take so slow to copy the data to the new HDD, almost 1days, only get 165GB data it run quiet slow
