I was able to set all 4 drives as "Non-Raid Disks" and then re-create the array in the BIOS. The drives were never disconnected from their SATA ports so I know they are in the correct order.
I was able to successfully run TestDisk -> Analyze -> Quick Scan -> Deeper Scan. The Deeper Scan found all my Partitions and was able to show me the correct files and all the data in them. However when I tried to 'Write' the Partitions I got a "Partition: Write error" - file_pwrite(5,32,buffer,2(0/0/3)) write err Read-only file system
This is a Win7 pc and the partitions were created in Win7. The Raid array is NOT encrypted. I only have MS Security Essentials currently running for AV. Currently the entire Raid array shows up as "Disk 1 Unknown 4191.79GB Not Initialized" in Disk Management.
Any help figuring out how to 'Write' the partitions would be GREATLY appreciated.
I have attached my TestDisk log
Here is a snippet from the end of the TestDisk Log:
1 P MS Data 264192 419694584 419430393 [Programs]
2 P MS Data 419694592 839124991 419430400 [Data]
3 P MS Data 839124992 1258555391 419430400 [Data II]
4 P MS Data 1258555392 5452859391 4194304000 [Photos]
5 P MS Data 5452859392 6501435384 1048575993 [Artwork]
write!
Analyse Disk /dev/sdb - 4500 GB / 4191 GiB - CHS 547203 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=2930277167 (expected 8790816767)
hdr_lba_start=34
hdr_lba_end=2930277134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 419694591 419430400 [Basic data partition] [Programs]
3 P MS Data 419694592 839124991 419430400 [Basic data partition] [Data]
4 P MS Data 839124992 1258555391 419430400 [Basic data partition] [Data II]
5 P MS Data 1258555392 5452859391 4194304000 [Basic data partition] [Photos]
6 P MS Data 5452859392 6501435391 1048576000 [Basic data partition] [Artwork]
