Cf card recovery of canon 5dmkII files
wolfy
#1 Post by wolfy »
I have been having a long a frustrating time trying to access the files on a corrupt Sandisk 16gb cf card.
This test disk sounds like amazing software but I'm getting nothing out of it.
No partition is found no matter what I do.
What are you supposed to do with that and get past this block?
I've tried quick search and deep search and both come up with nothing.
I also have 2 version of the same disk but with one having (RO) at the end. What does this mean?
It's very frustrating that there isn't a better guide for this software so more people can use it.
I was logged in as sudo.
I'm using a MacBook Pro.
Thanks
Re: Cf card recovery of canon 5dmkII files
RO=Read Only. Mac OS X locks device in read-only mode when a partition from the disk is currently mounted.
Have you try to recover your data with PhotoRec ? If the filesystem is corrupted, choose [Whole] instead of [Free] when asked.
