Hello.
I managed to 'lose' my external HDD data by running a convert from FAT32 to NTFS (after hitting a file size limitation). The convert failed whilst in progress, despite running CHKDSK etc clean prior to starting conversion.
I immediately set the drive back to FAT32 in the hope of recovering the FAT and thus the files and directory structures with a view to relocating the files and re-running the conversion.
I don't believe that these is any hardware error in the external drive but rather that we suffered a very minor power blip or a USB issue.
I tried using Testdisk yesterday, but don't get the option to Repair FAT which is what I think I need, even after trying a number of BOOT options from the menus.
At this point, I kicked off an Image copy, as I realised I wasn't sure what I was doing and didn't want to cause any further risk to recovery, and am now running Photorec against the Image DD to secure some raw data. The recovery is 1+ hour in with about 20+ hours to go and it has recovered over 7000 files (although a lot - aside from JPGs seem to be corrupted).
When photorec has completed, what I would like to do is go back and try to recreate the FAT (and thus the filesystem and files?) if that is possible, and would appreciate guidance as to how exactly to achieve this.
Thanks and Regards
Steve O.
FAT32 External HDD - Recovering the FAT? Topic is solved
Re: FAT32 External HDD - Recovering the FAT?
It's not recommended to modify anything to a corrupted file system.
Chdsk and Repair Fat are only recommeded if someone tries to repair a file system.
Can you run a diagnose using testdisk to determine your current situation?
It means, Analyse, Quick and if no partition or data are found running Deeper Search.
Can you copy and paste the content of your testdisk.log into your next post?
Hello Fiona - thanks for the quick response.
Photorec is still running against image.dd on my 2nd USB drive so I initiated a 2nd Testdisk window and plugged the original Seagate USB drive in as well.
Testdisk found a partition, but P to list files only listed 3 empty tmp directories from around the time of the original problem.
I am currently running Testdisk Deeper search (16% complete) and will post the log file upon completion.
Steve O.
Steve O.
Hello.
just got in - Tesdisk has finished - however it looks like Photorec stalled a couple of hours ago so I have just canned and resumed that session.
Here is the Tesdisk log - it is quite large but you asked me to paste it so here it is............
Tue Oct 1 13:54:54 2013
TestDisk 7.0-WIP, Data Recovery Utility, August 2013
Compilation date: 2013-09-19T08:43:48
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=94319411200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=11943076864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=320070288384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=5558501376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=750145503744
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SAMSUNG SSD 830 Seri, S/N:0SJWENCA073599, FW:CXM0
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD75 00BPKT-75PK4T0, S/N:3471635A11XW-DW, FW:01.0
Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - Seagate External Drive
Disk /dev/sdc - 320 GB / 298 GiB - Seagate External Drive
Analyse Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63
FAT32 at 0/1/1
Info: size boot_sector 625137282, partition 625137282
FAT1 : 32-38182
FAT2 : 38183-76333
start_rootdir : 76334 root cluster : 2
Data : 76334-625137197
sectors : 625137282
cluster_size : 128
no_of_cluster : 4883288 (2 - 4883289)
fat_length 38151 calculated 38151
1 * FAT32 0 1 1 38912 254 63 625137282 [NO NAME]
FAT32 at 0/1/1
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/1
FAT32 LBA 0 1 1 38912 254 63 625137282 [NO NAME]
FAT32, blocksize=65536, 320 GB / 298 GiB
file_pread(6,2,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(6,1,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(6,8,buffer,625142463(38913/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,625142463(38913/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,625142591(38913/83/18)) lseek err Invalid argument
file_pread(6,8,buffer,625142719(38913/85/20)) lseek err Invalid argument
file_pread(6,8,buffer,625142847(38913/87/22)) lseek err Invalid argument
file_pread(6,8,buffer,625142975(38913/89/24)) lseek err Invalid argument
file_pread(6,8,buffer,625143103(38913/91/26)) lseek err Invalid argument
file_pread(6,8,buffer,625143231(38913/93/28)) lseek err Invalid argument
file_pread(6,8,buffer,625143359(38913/95/30)) lseek err Invalid argument
file_pread(6,8,buffer,625143487(38913/97/32)) lseek err Invalid argument
file_pread(6,8,buffer,625143615(38913/99/34)) lseek err Invalid argument
file_pread(6,8,buffer,625143743(38913/101/36)) lseek err Invalid argument
file_pread(6,1,buffer,625143807(38913/102/37)) lseek err Invalid argument
file_pread(6,14,buffer,625143809(38913/102/39)) lseek err Invalid argument
file_pread(6,3,buffer,625143823(38913/102/53)) lseek err Invalid argument
file_pread(6,3,buffer,625143870(38913/103/37)) lseek err Invalid argument
file_pread(6,8,buffer,625143886(38913/103/53)) lseek err Invalid argument
file_pread(6,11,buffer,625143933(38913/104/37)) lseek err Invalid argument
file_pread(6,2,buffer,625145855(38913/135/6)) lseek err Invalid argument
* FAT32 LBA 0 1 1 38912 254 63 625137282 [NO NAME]
dir_partition inode=0
FAT: cluster=2(0x2), pos=76397
3 drwxr-xr-x 0 0 0 12-Aug-2013 21:45 $RECYCLE.BIN
X 5 drwxr-xr-x 0 0 65536 12-Aug-2013 22:47 MSIbc8b4.tmp
X 5 drwxr-xr-x 0 0 65536 12-Aug-2013 22:48 MSIbc8bd.tmp
X 5 drwxr-xr-x 0 0 65536 12-Aug-2013 22:48 MSIbc8c5.tmp
dir_partition inode=5
FAT: cluster=5(0x5), pos=76781
Directory /MSIbc8b4.tmp
5 drwxr-xr-x 0 0 0 12-Aug-2013 22:48 .
0 drwxr-xr-x 0 0 0 12-Aug-2013 22:48 ..
Directory /MSIbc8bd.tmp
Directory /MSIbc8c5.tmp
1 * FAT32 LBA 0 1 1 38912 254 63 625137282 [NO NAME]
FAT32 at 0/1/1
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/7
NTFS at 38912/254/63
filesystem size 625137282
mftmirr_lcn 2
HPFS - NTFS 0 1 1 38912 254 63 625137282
NTFS found using backup sector, blocksize=4096, 320 GB / 298 GiB
mftmirr_lcn 2
file_pread(6,1024,buffer,631431872(39304/208/9)) lseek err Invalid argument
file_pread(6,1,buffer,631431872(39304/208/9)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 38912 254 63 77825 253 62 625137282
NTFS, blocksize=4096, 320 GB / 298 GiB
This partition ends after the disk limits. (start=625137344, size=625137282, end=1250274625, disk end=625142448)
The harddisk (320 GB / 298 GiB) seems too small! (< 640 GB / 596 GiB)
dir_partition inode=3
FAT: cluster=3(0x3), pos=76525
Directory /$RECYCLE.BIN
3 drwxr-xr-x 0 0 0 12-Aug-2013 21:45 .
0 drwxr-xr-x 0 0 0 12-Aug-2013 21:45 ..
4 -rwxr-xr-x 0 0 129 12-Aug-2013 21:45 DESKTOP.INI
ntfs_readdir failed for cluster 5
5 dr-xr-xr-x 0 0 0 12-Aug-2013 21:28 .
5 dr-xr-xr-x 0 0 0 12-Aug-2013 21:28 ..
Steve O.
FAT32 at 0/1/1
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/1
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/1
FAT32 at 0/1/1
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-38182
FAT2 : 38183-76333
sectors : 625137282
cluster_size : 128
FAT32 at 0/1/7
mftmirr_lcn 2
mftmirr_lcn 2
Steve O.
It looks like the corruption is too severe for TestDisk. Try PhotoRec instead.
Hello again.
Thanks for trying anyway.
My attempts with photorec (see above where I was running recoveries in parallel - one using Testdisk on the drive and the other using photorec on an image.dd of the drive) kept hanging up.
I was eventually able, using the Resume function in photorec,to save every minute or so, to get to a point where it hangs immediately.
Of the files recovered by photorec, there are a lot of 'good' jpegs - so I guess it is good at doing what it was designed for. However most of the AVI and DOC files, and a lot of the PDF files are corrupted and none of the executables seem to be executable and they have lost their original names.
The good news is that some success has been had using a commercial product - it seems to have recovered the files, with original names, along with the original directory structures.
Steve O.
Steve O.
