External HDD Partition table and FAT boot sector wiped out
kiggiss
#1 Post by kiggiss »
Good day everybody,
It happened eventually, my external HDD 1,5 TB lost all its data. Here what happened.
I was trying to make an bootable USB drive using Ubuntu Startup Disk Creator. I connected USB stick and on the other port external HDD where .iso file was stored. Apparently, however I am not sure, when I chosen source and destination I messed up my HDD and USB stick and accidentally wiped out HDD bootable sector or partition table. I might be wrong in details. The USB stick was not created and at the same time my HDD now appeared in Linux Ubuntu as 1,5 TB Harddrive pristinely clean. Windows does not recognise it at all.
I run testdisk and it found the partition is FAT32, but once I precced p to list files, I have message no files were found. Now I am running deep search and want to attached printscreen. It is on 70% and I would like to ask you what to do further.
Thank you in advance.
added later:
Eventually scanning was completed. Message on the screen appeared:
The harddisk (1500 GB/ 1397 GiB) seems too small! (<4367 GB/ 4067 GiB)
FAT32 LBA 229535 151 45 ............(many digits)
FAT16 LBA 273656 ........(many digits)
[ Continue ]
582GB/ 542 GiB
What to choose Continue or press q for quit?
