I formatted an xfs partition to ext4 by mistake. Can this be reverted to xfs and the previous data recovered?
Regards.
						Xfs partition formatted to ext4 by mistake, recovery? Topic is solved
Re: Xfs partition formatted to ext4 by mistake, recovery?
Testdisk couldn't do anything. I was able to use photorec to restore the data, music files mostly, and using Musicbrainz Picard I was able to then rename the restored file automatically.
