I unwittingly deleted some photos before they were transferred to the external hard drive from iphoto.
Trying to recover but not sure how to do it.
There is a back up file for the system in the .trashes folder on the external hard drive however this is light gray and I cannot save it to the desktop as the start up disk is full.
When I start up PhotoRec there are four options: >Disk/dev/disk2-1000 GB/931GiB (RO); >Disk/dev/disk3-1000 GB/931GiB (RO), >Disk/dev/rdisk2-1000 GB/931GiB (RO), >Disk/dev/rdisk3-1000 GB/931GiB (RO).
I am unsure what these disks are and am unsure of how to proceed.
I would either like to retrieve the photos from the Mac hard drive or the back up files from the external hard drive.
Advice?
Thank you.
Mac file recover Toshiba external hard drive
Re: Mac file recover Toshiba external hard drive
You should follow http://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
TestDisk lists the disk it can access. In your case, it lists 2 disks, each with a disk and a rdisk device. It's better to use a rdisk device than a disk device. If your disk isn't one of those two, choose Sudo.
External disks are usually mounted in /Volumes, so got to this folder if you want to save the files to an external disk.
