photorec glibc 2.18 segfault Topic is solved
fruitC
#1 Post by fruitC »
I'm trying to recover some lost data from an raw drive image (created wit dd_rescue).
Photorec always segfaults after 900-1000 files. I tried with several disk images, all containing FAT12 to FAT32 partitions. I tried with the pre-compiled 6.14-1 version from my ArchLinux repo, and with the self-compiled 7.0-WIP and with the current git... same result.
The segfault is at:
"file_reg.c:79 if(memcmp(block,"RGDB",4)!=0)" (__memcmp_sse4_1 () from /usr/lib/libc.so.6)
#0  0x00007ffff6c15444 in __memcmp_sse4_1 () from /usr/lib/libc.so.6
No symbol table info available.
#1  0x00000000004428b9 in header_check_reg_9x (buffer=0x7ffff7f7e800 "CREG", buffer_size=65536, safe_header_only=0, file_recovery=0x7fffffffd590, file_recovery_new=0x7fffffffccd0)
    at file_reg.c:79
        header = 0x7ffff7f7e800
        block = 0x7ffff801ec00
#2  0x00000000004224af in photorec_aux (params=0x7fffffffe270, options=0x7fffffffe2d0, list_search_space=0x698a00 <list_search_space.6939>) at psearchn.c:195
        file_check = 0x7f47d0
        tmp = 0x7f47d0
        pos = 0x87f000
        tmpl = 0x882000
        file_recovery_new = {
          filename = "\000kLFT3\000k\000\212i\000\000\000\000\000\320\342\377\377\377\177\000\000p\342\377\377\377\177\000\000\000XT3\000kNXT4\000kNXT5\000kNXT6\000kNXT7\000kPRV3\000kPRV4\000kPRV5\000kPRV6\000kPRV7\000kRIT3\000kRIT4\000kRIT5\000kRIT6\000kRIT7\000kUP\000kUP3\000kUP4\000kUP5\000kUP6\000kUP7\000ka2\000kb1\000kb3\000kc2", '\000' <repeats 11 times>, "p\323\377\377\377\177\000\000`\323\377\377\377\177\000\000\f\232\261\366\377\177\000\000"..., location = {list = {next = 0x7fffffffd4d0, prev = 0x7fffffffd4d0}, start = 417644032, end = 0,
            data = 0}, loc = 0xf00690, file_stat = 0x0, handle = 0x0, time = 0, file_size = 0, file_size_on_disk = 0, extension = 0x47a660 "exe", min_filesize = 0, offset_ok = 0,
          offset_error = 0, extra = 0, calculated_file_size = 0, data_check = 0x0, file_check = 0x0, file_rename = 0x0, checkpoint_offset = 0, checkpoint_status = 0, blocksize = 1024,
          flags = 0}
        file_recovered = 0
        old_offset = 419126784
        offset = 419126784
        buffer_start = 0x7ffff7f65000 ""
        buffer_olddata = 0x7ffff7f7e400 "\313\211]\374t\vS\377u\b\350\322n\001"
        buffer = 0x7ffff7f7e800 "CREG"
        start_time = 1381474354
        previous_time = 1381474355
        next_checkpoint = 1381474654
        ind_stop = PSTATUS_OK
        buffer_size = 525312
        blocksize = 1024
        read_size = 65536
        offset_before_back = 417644032
        back = 0
        current_search_space = 0xf00690
        file_recovery = {
          filename = "/data/data2/rec/recup_dir.7/f0815711.exe\000\064\000kNXT5\000kNXT6\000kNXT7\000kPRV3\000kPRV4\000kPRV5\000kPRV6\000kPRV7\000kRIT3\000kRIT4\000kRIT5\000kRIT6\000kRIT7\000kUP\000kUP3\000kUP4\000kUP5\000kUP6\000kUP7\000ka2\000kb1\000kb3\000kc2", '\000' <repeats 11 times>, "p\323\377\377\377\177\000\000`\323\377\377\377\177\000\000\f\232\261\366\377\177\000\000"..., location = {list = {next = 0x7fffffffdd90, prev = 0x7fffffffdd90}, start = 417644032, end = 0, data = 0}, loc = 0xf00690, file_stat = 0x7fe4a0, handle = 0xf006d0, time = 0,
          file_size = 1482752, file_size_on_disk = 1482752, extension = 0x47a660 "exe", min_filesize = 0, offset_ok = 0, offset_error = 0, extra = 0, calculated_file_size = 0,
          data_check = 0x0, file_check = 0x0, file_rename = 0x0, checkpoint_offset = 0, checkpoint_status = 0, blocksize = 1024, flags = 0}
#3  0x000000000041f591 in photorec (params=0x7fffffffe270, options=0x7fffffffe2d0, list_search_space=0x698a00 <list_search_space.6939>) at phrecn.c:457
        old_file_nbr = 0
        blocksize_is_known = 0
#4  0x0000000000421b88 in menu_photorec (params=0x7fffffffe270, options=0x7fffffffe2d0, list_search_space=0x698a00 <list_search_space.6939>) at ppartsel.c:409
        element = 0x0
        i = 2
        list_part = 0x79dcd0
        current_element = 0x79dcd0
        current_element_num = 0
        user_blocksize = 0
        done = 0
        mode_init_space = INIT_SPACE_WHOLE
        command = 83
        offset = 0
        menu = 0
        menuMain = {{key = 83, name = 0x477bef "Search", desc = 0x477bf6 "Start file recovery"}, {key = 79, name = 0x477c0a "Options", desc = 0x477c12 "Modify options"}, {key = 70,
            name = 0x477c21 "File Opt", desc = 0x477c2a "Modify file options"}, {key = 71, name = 0x477c3e "Geometry", desc = 0x477c47 "Change disk geometry"}, {key = 81,
            name = 0x477c5c "Quit", desc = 0x477c61 "Return to disk selection"}, {key = 0, name = 0x0, desc = 0x0}}
#5  0x000000000041b315 in photorec_disk_selection_ncurses (params=0x7fffffffe270, options=0x7fffffffe2d0, list_disk=0x6c1270, list_search_space=0x698a00 <list_search_space.6939>)
    at pdisksel.c:283
        disk = 0x79d740
        hpa_dco = 0
        menu_options = 0x4765c9 "OQ"
        i = 1
        command = 79
        real_key = 13
        menu = 2
        offset = 0
        pos_num = 0
        use_sudo = 0
        element_disk = 0x0
        current_disk = 0x6c1270
        menuMain = {{key = 80, name = 0x4765fa "Previous", desc = 0x476603 ""}, {key = 78, name = 0x476604 "Next", desc = 0x476603 ""}, {key = 79, name = 0x476609 "Proceed",
            desc = 0x476603 ""}, {key = 83, name = 0x476611 "Sudo", desc = 0x476618 "Use the sudo command to restart as root"}, {key = 81, name = 0x476640 "Quit",
            desc = 0x476645 "Quit program"}, {key = 0, name = 0x0, desc = 0x0}}
#6  0x000000000041b473 in do_curses_photorec (params=0x7fffffffe270, options=0x7fffffffe2d0, list_disk=0x6c1270) at pdisksel.c:331
        list_search_space = {list = {next = 0x7c7e60, prev = 0xf00690}, start = 0, end = 0, file_stat = 0x0, data = 0}
#7  0x0000000000404db3 in main (argc=2, argv=0x7fffffffe468) at phmain.c:365
        i = 2
        use_sudo = 0
        help = 0
        version = 0
        create_log = 0
        run_setlocale = 1
        testdisk_mode = 8
        list_disk = 0x6c1270
        element_disk = 0x0
        logfile = 0x471c64 "photorec.log"
        log_handle = 0x0
        log_errno = 0
        options = {paranoid = 1, keep_corrupted_file = 0, mode_ext2 = 0, expert = 0, lowmem = 0, verbose = 0, list_file_format = 0x69baa0 <list_file_enable>}
        params = {cmd_device = 0x0, cmd_run = 0x0, disk = 0x79d740, partition = 0x79db60, carve_free_space_only = 0, blocksize = 1024, pass = 1, status = STATUS_EXT2_OFF,
          real_start_time = 1381474354, recup_dir = 0x800fa0 "/data/data2/rec/recup_dir", dir_num = 7, file_nbr = 3060, file_stats = 0x7fe000, offset = 112467456}
(gdb) up
    at file_reg.c:79
(gdb)
Using locale 'C'.
Fri Oct 11 09:01:20 2013
Command line: PhotoRec /log /debug XP6
PhotoRec 7.0-WIP, Data Recovery Utility, August 2013
OS: Linux, kernel 3.10.15 (#1 SMP PREEMPT Tue Oct 8 10:24:42 CEST 2013) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-11T08:37:53
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, ewf lib: none, libjpeg: libjpeg-turbo-1.3.0
Disk XP6 - 2111 MB / 2014 MiB - CHS 257 255 63 (RO), sector size=512
Geometry from i386 MBR: head=64 sector=63
FAT32 at 0/1/1
Info: size boot_sector 4120640, partition 4120641
FAT1 : 38-4054
FAT2 : 4055-8071
start_rootdir : 8072 root cluster : 2
Data : 8072-4120639
sectors : 4120640
cluster_size : 8
no_of_cluster : 514071 (2 - 514072)
fat_length 4017 calculated 4017
heads/cylinder 64 (FAT) != 255 (HD)
     No partition             0   0  1   256 191 63    4124736 [Whole disk]
 1 * FAT32                    0   1  1   256 127 63    4120641 [IRIS]
     FAT32, blocksize=4096, 2109 MB / 2012 MiB
602 first-level signatures enabled
Analyse
Pass 0 (blocksize=512) STATUS_FIND_OFFSET
* 0-4124735: (null)
4124736 sectors contains unknown data, 0 invalid files found and rejected.
Elapsed time 0h00m00s
Pass 1 (blocksize=1024) STATUS_EXT2_OFF
* 1-62: (null)
63-68: fat
69-8414: fat
8415-8422: fat
8423-8518: fat
8519-8526: cab
8527-8702: cab
8703-8862: cab
8863-9126: cab
9127-11814: cab
11815-4124735: lnk
4124735 sectors contains unknown data, 10 invalid files found and rejected.
Sector 8415
      37 drwxr-xr-x     0      0         0 16-Sep-2004 14:43 .
       0 drwxr-xr-x     0      0         0 16-Sep-2004 14:43 ..
      38 drwxr-xr-x     0      0         0 16-Sep-2004 15:03 TEMP
    1285 drwxr-xr-x     0      0         0 16-Sep-2004 15:03 ARCHIVE
    1800 drwxr-xr-x     0      0         0 16-Sep-2004 15:03 LOGS
    2315 drwxr-xr-x     0      0         0 16-Sep-2004 15:03 SFP
    2316 drwxr-xr-x     0      0         0 16-Sep-2004 15:03 EXTRACT
  188479 -rwxr-xr-x     0      0        52 26-Oct-2004 12:04 DSINFO.DAT
    2318 -rwxr-xr-x     0      0     62374 16-Sep-2004 15:03 VxDMon.dat
    2334 -rwxr-xr-x     0      0         1 16-Sep-2004 15:03 SRDISKID.DAT
    2335 -rwxr-xr-x     0      0       104 16-Sep-2004 15:03 DISKCFG.DAT
       9 -rwxr-xr-x     0      0        28 26-Oct-2004 12:04 VxDMon.cfg
/data/data2/rec/recup_dir.7/f0812119.fat         812119-812120
Sector 812127
  100501 drwxr-xr-x     0      0         0 16-Sep-2004 14:35 .
  100500 drwxr-xr-x     0      0         0 16-Sep-2004 14:35 ..
  100502 -rwxr-xr-x     0      0      2059  8-Jun-2000 19:00 CHART.JS
  100503 -rwxr-xr-x     0      0      3212  8-Jun-2000 19:00 EXCEL.JS
  100504 -rwxr-xr-x     0      0      3919  8-Jun-2000 19:00 NETWORK.JS
  100505 -rwxr-xr-x     0      0      2586  8-Jun-2000 19:00 REGISTRY.JS
  100506 -rwxr-xr-x     0      0      2281  8-Jun-2000 19:00 SHORTCUT.JS
  100507 -rwxr-xr-x     0      0      1845  8-Jun-2000 19:00 CHART.VBS
  100508 -rwxr-xr-x     0      0      3076  8-Jun-2000 19:00 EXCEL.VBS
  100509 -rwxr-xr-x     0      0      5378  8-Jun-2000 19:00 NETWORK.VBS
  100511 -rwxr-xr-x     0      0      2347  8-Jun-2000 19:00 REGISTRY.VBS
  100512 -rwxr-xr-x     0      0      2126  8-Jun-2000 19:00 SHORTCUT.VBS
  100513 -rwxr-xr-x     0      0      1941  8-Jun-2000 19:00 SHOWVAR.VBS
/data/data2/rec/recup_dir.7/f0812127.fat         812127-812128
/data/data2/rec/recup_dir.7/f0812135.txt         812135-812140
/data/data2/rec/recup_dir.7/f0812143.txt         812143-812150
/data/data2/rec/recup_dir.7/f0812151.txt         812151-812158
/data/data2/rec/recup_dir.7/f0812159.txt         812159-812164
/data/data2/rec/recup_dir.7/f0812167.txt         812167-812172
/data/data2/rec/recup_dir.7/f0812175.txt         812175-812178
/data/data2/rec/recup_dir.7/f0812183.txt         812183-812188
/data/data2/rec/recup_dir.7/f0812191.txt         812191-812202
/data/data2/rec/recup_dir.7/f0812207.txt         812207-812212
/data/data2/rec/recup_dir.7/f0812215.txt         812215-812220
changing the memcmp function to builtin or -mno-sse4 does not work.
My system: Linux 3.10.15 PREEMPT x86_64
Re: photorec glibc 2.18 segfault
I have uploaded a new 7.0-WIP version. Do you still have the problem ?
fruitC
#3 Post by fruitC »
It works perfect now :)
Thank you.
