Also, ich habe jetzt TestDisk gestartet und bin hier gelandet:
Zuerst ein Screenie der betreffenden HD:
Und nun der erste Schritt:
TestDisk 6.11, Data Recovery Utility, April 2009
Disk /dev/sda - 120 GB / 111 GiB - ATA WDC WD1200JB-00F
Disk /dev/sdb - 1000 GB / 931 GiB - ATA SAMSUNG HD103SI
[Proceed ] [ Quit ]
If a disk listed above has incorrect size, check HD jumper settings, BIOS
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63
1 * Linux 0 1 1 6686 254 63 107426592 [LinuxMintKDE]
2 P Linux 6687 0 1 14592 254 63 127009890 [LinuxMint old]
[ Type ] [Superblock] [Image Creation] [ Quit ]
Locate ext2/ext3/ext4 backup superblock
Linux 6687 0 1 14592 254 61 127009888 [LinuxMint old]
superblock 0, blocksize=4096 [LinuxMint old]
superblock 32768, blocksize=4096 [LinuxMint old]
superblock 98304, blocksize=4096 [LinuxMint old]
superblock 163840, blocksize=4096 [LinuxMint old]
superblock 229376, blocksize=4096 [LinuxMint old]
superblock 294912, blocksize=4096 [LinuxMint old]
superblock 819200, blocksize=4096 [LinuxMint old]
superblock 884736, blocksize=4096 [LinuxMint old]
superblock 1605632, blocksize=4096 [LinuxMint old]
superblock 2654208, blocksize=4096 [LinuxMint old]
[ Quit ]
Return to Advanced menu
