Hi all,
Thanks in advance for your help.
I have a 1TB WD external USB hard drive and accidentally unplugged it without ejecting it from my Macbook. Now, after I unlock it, the hard drive doesn't mount. But I can see the partition in Disk Utility. I think it's just a boot sector issue. No physical issue with the drive.
Here's what I did with testdisk:
Sun Apr  8 02:26:58 2012
OS: Darwin, kernel 11.3.0 (Darwin Kernel Version 11.3.0: Thu Jan 12 18:47:41 PST 2012; root:xnu-1699.2
Compiler: GCC 4.0
Compilation date: 2011-11-15T08:36:43
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
User is not root!
Disk /dev/disk1 - 30 MB / 28 MiB - CHS 12800 1 1 (RO), sector size=2352
Disk /dev/disk2 - 1000 GB / 931 GiB - CHS 1953468416 1 1, sector size=512
Disk /dev/rdisk1 - 30 MB / 28 MiB - CHS 12800 1 1 (RO), sector size=2352
Disk /dev/rdisk2 - 1000 GB / 931 GiB - CHS 1953468416 1 1, sector size=512
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - CHS 1953468416 1 1
BAD_RS LBA=2 1339
NTFS at 2/0/1
get_geometry_from_list_part_aux head=1 nbr=2
Warning: Incorrect number of heads/cylinder 255 (NTFS) != 1 (HD)
Warning: Incorrect number of sectors per track 63 (NTFS) != 1 (HD)
 1 * HPFS - NTFS                    2 1953468415 1953468414 [BACKUP]
Ask the user for vista mode
search_vista_part: 1
NTFS at 2/0/1
filesystem size           1953468414
sectors_per_cluster       8
mft_lcn                   3
mftmirr_lcn               122091775
clusters_per_mft_record   -10
     NTFS, 1000 GB / 931 GiB
BAD_RS LBA=2 1339
NTFS at 2/0/1
ntfs_boot_sector
NTFS at 2/0/1
NTFS at 2/0/1
mft_lcn                   3
Status: OK
Status: OK
Sectors are identical.
ntfs_attr_find: Corrupt inode (5): Input/output error
Failed to open index allocation attribute. Directory inode 5 is corrupt or bug: Input/output error
ntfs_mst_post_read_fixup: magic: 0x001567ab  size: 1024  usa_ofs: 0  usa_count: 65535: Invalid argument
Record 6 has no FILE magic (0x1567ab)
Failed to open inode FILE_Bitmap: Input/output error
Record 5 has no FILE magic (0x1567ab)
repair_MFT
NTFS at 2/0/1
NTFS Volume is dirty.
ntfs_readdir failed
ntfs_dir: ntfs_inode_open failed
ntfs_boot_sector
NTFS at 2/0/1
NTFS at 2/0/1
mft_lcn                   3
Status: OK
Status: OK
So when I go into List, it shows no files. There should be hundreds of gigs of stuff on the drive.
I'm confused as to my next step after selecting Rebuild BS. Do I dump? Do I write?
And since there's nothing in List, is that what will appear once I've selected "Dump" or "Write"?
Thanks,
Zack
						1TB WD Hard drive not mounting on Mac
Re: 1TB WD Hard drive not mounting on Mac
It looks like your file system is damaged!NTFS Volume is dirty.
Your boot sector and its backup are OK.ntfs_boot_sector
NTFS at 2/0/1
NTFS at 2/0/1
mft_lcn 3
Status: OK
Status: OK
Messages about geometry can be ignored as long as your partition is found by TestDisk.
Your label is displayed also.
Probably depend on, that your partition was created using windows?
Actually, I don't recommend to change anything to a file system if it's damaged.
A safe solution to recover data might be datarecovery software.
You can have a look at PhotoRec.
Info;
PhotoRec doesn't keep file names and directories.
But it's capable to recover files from seriusly damaged file systems and large disks.
Otherwise you should have a look to commercial software.
Afterwards you can consider to have a try to repair your files system using windows and chkdsk.
Under win7/Vista you must have administrator privileges.
You should use the command prompt and try chkdsk driveletter: /r.
				zackbaddorf
Hi Fiona,
Thanks so much for your help!
I think what I did was format the drive on my Macbook in NTFS. So I found a tool for Macs called DiskDrill. Heard of this? It has a deep scan for lost data. Is that what I should do?
When I plug the drive into a Windows machine, it says the drive is not formatted. And that makes me think that there's some sort of boot sector or file system problem. Is that not the case? Can TestDisk do anything to help with the file system problems?
And would you recommend that I "Repair Disk" under Mac's Disk Utility? I've never used that before and am uncertain what it will do.
Thanks!
Zack
Thanks!
Zack
