I am trying to recover files on my Western Digital external hard drive. TestDisk stops at the same point "Partition: Read error"
The log file is below. I dont know how to paste an image here to show you a screen shot.
I'd be grateful for any help
Tue Nov 19 18:14:31 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=107268276224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=212697350144
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - TOSHIBA MK3276GSX, S/N:9 T2CLZHTE, FW:GS00
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD My Passport 0740, S/N:WX81CC105751, FW:1007
Disk /dev/sdc - 1000 GB / 931 GiB - WD My Passport 0740
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121597 255 63
Unable to use my external drive
Re: Unable to use my external drive
Does your disk made strange noises ? It's probably a hardware problem, you need to contact a data recovery company.
No noises at all.
Try PhotoRec. If after a few minutes it has recovered some files, try to clone your disk using gnu ddrescue
If it's not the case, my previous advice to contact a data recovery company still hold.
