I have a hard drive that was internal to my laptop that I have now removed and wish to use as an external device via USB. I put it in an enclosure and it was working fine, but something has gone wrong. I think the connector on the enclosure is broken. I used an SATA to USB cable to connect the drive. It assigns a drive letter, but says that the device must be formatted. checked it in disk management under windows 7, tried chkdsk /f and said it is a RAW data.
When I bring it up in TestDisk it finds the partitions, and I can see all of the files on the partitions. I try to repair the boot sector and master boot record, but I keep getting "write" errors. Any suggestions/advice would be greatly appreciated!!
Below is my log file:
Tue Nov 19 13:21:56 2013
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=127928369152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=750156374016
Disk \\.\PhysicalDrive0 - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 750 GB / 698 GiB - CHS 11400 255 63, sector size=4096
Drive C: - 127 GB / 119 GiB - CHS 15553 255 63, sector size=512
Drive E: - 750 GB / 698 GiB - CHS 11400 255 63, sector size=4096
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 0/162/35
Info: size boot_sector 1540096, partition 192512
NTFS at 12/158/19
Info: size boot_sector 1463517184, partition 182939648
1 * HPFS - NTFS 0 162 35 12 158 18 192512 [RECOVERY]
NTFS, blocksize=4096, 788 MB / 752 MiB
2 P HPFS - NTFS 12 158 19 11400 22 14 182939648 [OS]
NTFS, blocksize=4096, 749 GB / 697 GiB
ntfs_boot_sector
NTFS at 0/162/35
filesystem size 1540096 1470706680935409875
sectors_per_cluster 8 84
mft_lcn 64170 2339999267
mftmirr_lcn 2 4294451332
clusters_per_mft_record -10 -52
clusters_per_index_record 1 -52
Status: OK
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 2, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 64170
ntfs_find_mft: mftmirr_lcn 2
ntfs_find_mft: sectors_per_cluster 1
New / Current boot sector
filesystem size 192512 1540096
sectors_per_cluster 1 8
mft_lcn 64170 64170
mftmirr_lcn 2 2
clusters_per_mft_record -10 -10
clusters_per_index_record 1 1
mft_lcn 64170 64170
mftmirr_lcn 2 2
Write new boot!
Write error: Can't write new NTFS boot sector
Write error: Can't write new NTFS backup boot sector
ntfs_boot_sector
NTFS at 0/162/35
NTFS at 0/162/35
mft_lcn 64170
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
Change partition type:
ntfs_boot_sector
NTFS at 12/158/19
filesystem size 1463517184 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
Status: Bad
rebuild_NTFS_BS
ntfs_find_mft: mft_lcn 786432
filesystem size 182939648 1463517184
mft_lcn 786432 786432
mftmirr_lcn 2 2
mftmirr_lcn 2 2
Write new boot!
ntfs_boot_sector
NTFS at 12/158/19
NTFS at 12/158/19
mftmirr_lcn 2
Status: OK
Status: OK
Failed to open inode: Input/output error.
repair_MFT
NTFS at 12/158/19
ntfs_readdir failed for cluster 5
NTFS listing using MFT:
5 dr-xr-xr-x 0 0 0 14-Nov-2013 15:59 .
5 dr-xr-xr-x 0 0 0 14-Nov-2013 15:59 ..
ntfs_dir: ntfs_inode_open failed
ntfs_boot_sector
NTFS at 12/158/19
NTFS at 12/158/19
mftmirr_lcn 2
Status: OK
Status: OK
getting drive not formated error and cannot repair MBR
Re: getting drive not formated error and cannot repair MBR
Do you have the same problem with TestDIsk 7.0-WIP ?
