Hi all,
I accidently deleted my "archive" folder( 50gb) on my QNAP. Getting back only some of the files would be great.
I try to get it back using http://blogging.cwl.cc/2012/06/recover- ... p-nas.html
I never used Linux, so it is tough job to get a long. I'm stuck at "Run PhotoRec (photorec_static) in the shell by issuing a ./photorec_static command"
I used chmod to get all rights, then I type: ./photorec_static
but
-sh: ./photorec_static: cannot execute binary file
is returned to me.( I am in the folder where I unzipped the files: ...../rec)
Anybody here to help this poor dumb WINuser out of his mess? Thanks in advance
Newbie-Question- running photorec
Re: Newbie-Question- running photorec
You are probably running a version not adapted for your QNAP processor, it's why it failed.
I got a Qnap ts-412 with a Marvel CPU- the Qnap in the blog runs on Intels Atom: That's the reason?
Is there photoRec-version for my needs?
