I have used Testdisk several times to fix broken partitions. Always with success. Thank you very much. It is a great software.
However, yesterday I received a 1.5 TB Seagate Barracuda 7200.11.
My client tells me that it was working well, but suddenly broke down. Since then it is completely dead.
Using Debian, I installed it on my computer and heard some clicking. Then, it was detected by the system. To my surprise, as a 4 GB (!) disk.
I run Testdisk. There are no partitions. The disk size is still 4 GB.
Disk /dev/sdg - 4142 MB / 3950 MiB - ST_M13FQ BL
I choose the partition as an Intel one. I do Analyze and I obtain the following message:
Partition: Read error
I do Quick search and I obtain:
Disk /dev/sdg - 4142 MB / 3950 MiB - CHS 3950 64 32
I do Deeper search and I obtain :
Analyse cylinder 37/3949: 00%
Read error at 36/63/32 (lba=75775)
After a while, the Deeper search finishes with no results.
After some research, I have found that this model has a severe problem :
http://www.theinquirer.net/inquirer/new ... es-failing
Is there a a way of solving it with Testdisk ? If not what would you recommend ?
Thanks for your attention.
Best regards,
Javier Revilla
Lima, Peru
No partitions - Seagate Barracuda 7200.11
Re: No partitions - Seagate Barracuda 7200.11
If you heard an unusual noise when trying to use this disk, the head is probably dead. If it's the case, you need to contact a data recovery company, they will have to swap the heads.
Hello Christophe,
Indeed, the disk makes clicking noises, when connected. Then, it is recognized by the system (Debian), but as having only 4GB. I have examined it extensively with Testdisk and other software, but I always get Read Errors.
I will not be able to take the disk to a data recovery specialist. That kind of service is difficult to find in my country.
Is it true that Seagate has a serious manufacturing problem, with the Seagate Barracudas (7200.11 and 12) ?
If that is the case, I will stop buying their disks.
Thank you very much for your help.
And thank you for Testdisk, which is a great software.
Best regards,
Javier Revilla
Lima, Peru
Best regards,
Javier Revilla
Lima, Peru
If your disk size is not recognized correctly, it might be possible that the memory management LBA (logical block addressing) of your disk, doesn't fit either.
It's only related to your disk size recognition of 4 GB.
That's why you receive partition read error and read errors only.
Clicking noise normally indicates that your disk is physically damaged as already mentioned above and shouldn't be stressed anymore.
TestDisk doesn't access any firmware, that's why it's not possible to solve any firmware, elctronically or physically problems.
If you don't intend to use any datarecovery lab and if seagate doesn't provide any solution like firmware etc.. to fix the problem, you could have a look to hdat2.
http://www.hdat2.com/
But it's on your risk.
