Here's how it happened:
sdb1 - 680gb primary partition, ext4, around 300gb of data on it
sdb2 - 60gb primary partition, ext4, for backing up system from sda1 with rsync
While doing rsync backup on sdb2, I run gparted, which indicated that it cannot read partition table on sdb and displayed the whole of it as unallocated. I know that when I run gparted 30 earlier, the partition was still vissible.
Nevertheless, I thought that's because of rsync and I thought reboot would fix that, because sdb1 was still mounted, and I was accessing all the data on it with no issues.
When rsync was done, I rebooted an that was the last time I saw my data.
Automounting during boot gives me:
superblock could not be read or does not describe correct ext2 filesystem...Code: Select all
$ sudo fsck.ext4 -p -b 98304 -B 4096 /dev/sdb
fsck.ext4: Bad magic number in super-block while trying to open /dev/sdb
/dev/sdb:
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>Code: Select all
$ sudo e2fsck -b 8193 /dev/sdb
[sudo] password for juha:
e2fsck 1.42.8 (20-Jun-2013)
e2fsck: Bad magic number in super-block while trying to open /dev/sdb
e2fsck -b 8193 <device>I then went into testdisk and as I saw it detected sdb1 and sdb2 correctly, I selected "Write" on the partition table. Since then on, gparted sees both partitions, but it sees sdb1 as empty.
I then did this:
$ sudo fsck -n /dev/sdb1
fsck from util-linux 2.24
ext2fs_check_desc: Corrupt group descriptor: bad block for block bitmap
fsck.ext4: Group descriptors look bad... trying backup blocks...
fsck.ext4: Bad magic number in super-block while using the backup blocksfsck.ext4: going back to original superblock
Superblock has an invalid journal (inode 8).
Clear? no
fsck.ext4: Illegal inode number while checking ext3 journal for /dev/sdb1
/dev/sdb1: ********** WARNING: Filesystem still has errors **********It finds the partition (partition type is automatically selected as None) but it finds no files on sdb1, even after deep search.
It does find data on sdb2, but that's just system partition backup I don't care about at this point.
Also, just now I run this
]$ sudo fsck.ext4 -v /dev/sdb1
Clear<y>? yes
*** ext3 journal has been deleted - filesystem is now ext2 only ***
Note: if several inode or block bitmap blocks or part
of the inode table require relocation, you may wish to try
running e2fsck with the '-b 32768' option first. The problem
may lie only with the primary block group descriptors, and
the backup block group descriptors may be OK.
Block bitmap for group 256 is not in group. (block 1268396107)
Relocate<y>? yes
Inode bitmap for group 256 is not in group. (block 1125246092)
Relocate<y>? yes
Inode table for group 256 is not in group. (block 2088878841)
WARNING: SEVERE DATA LOSS POSSIBLE.
Relocate<y>? no
One or more block group descriptor checksums are invalid. Fix<y>? yes
Group descriptor 256 checksum is 0x6349, should be 0x9abd. FIXED.
Inode bitmap for group 257 is not in group. (block 2837529440)
Relocate<y>? yes
Inode table for group 257 is not in group. (block 2199953455)
Relocate<y>? no
Group descriptor 257 checksum is 0x02d4, should be 0xd13d. FIXED.
Block bitmap for group 258 is not in group. (block 3896597355)
Relocate<y>? yes
Inode bitmap for group 258 is not in group. (block 2097244160)
Relocate<y>? yes
Inode table for group 258 is not in group. (block 2609271215)
Relocate<y>? no
Group descriptor 258 checksum is 0xee91, should be 0xc246. FIXED.
Block bitmap for group 259 is not in group. (block 805546298)
Relocate<y>? yes
Inode bitmap for group 259 is not in group. (block 3538423854)
Relocate<y>? yes
Inode table for group 259 is not in group. (block 2924444292)
Relocate<y>? no
Group descriptor 259 checksum is 0xc190, should be 0x4c0d. FIXED.
Block bitmap for group 260 is not in group. (block 338739984)
Relocate<y>? yes
Inode bitmap for group 260 is not in group. (block 902864749)
Relocate<y>? yes
Inode table for group 260 is not in group. (block 1901539298)
Relocate<y>? no
Group descriptor 260 checksum is 0xac76, should be 0xac63. FIXED.
Block bitmap for group 261 is not in group. (block 1660969779)
Relocate<y>? yes
Inode bitmap for group 261 is not in group. (block 209743725)
Relocate<y>? yes
Inode table for group 261 is not in group. (block 879935846)
Relocate<y>? no
Group descriptor 261 checksum is 0x800e, should be 0x8fa5. FIXED.
Block bitmap for group 262 is not in group. (block 1705519300)
Relocate<y>? yes
Inode bitmap for group 262 is not in group. (block 1360743755)
Relocate<y>? yes
Inode table for group 262 is not in group. (block 4107065764)
Relocate<y>? no
Group descriptor 262 checksum is 0xc00d, should be 0xe8f3. FIXED.
Inode bitmap for group 263 is not in group. (block 2205583287)
Relocate<y>? yes
Inode table for group 263 is not in group. (block 3636737468)
Relocate<y>? yes
Group descriptor 263 checksum is 0x69a9, should be 0xb9a9. FIXED.
Block bitmap for group 264 is not in group. (block 1471470759)
Relocate<y>? yes
Inode bitmap for group 264 is not in group. (block 1725839977)
Relocate<y>? yes
Inode table for group 264 is not in group. (block 2144458553)
Relocate<y>? no
Group descriptor 264 checksum is 0xcd09, should be 0xea3a. FIXED.
Block bitmap for group 265 is not in group. (block 3617231787)
Relocate<y>? yes
Inode bitmap for group 265 is not in group. (block 2640198439)
Relocate<y>? yes
Inode table for group 265 is not in group. (block 2725347176)
Relocate<y>? no
Group descriptor 265 checksum is 0xbbb8, should be 0xb870. FIXED.
Block bitmap for group 266 is not in group. (block 1840499818)
Relocate<y>? yes
Inode bitmap for group 266 is not in group. (block 3698703324)
Relocate<y>? yes
Inode table for group 266 is not in group. (block 2882301371)
Relocate<y>? no
Group descriptor 266 checksum is 0xb3c9, should be 0x72d5. FIXED.
Block bitmap for group 267 is not in group. (block 1968099309)
Relocate<y>? yes
Inode bitmap for group 267 is not in group. (block 2125019324)
Relocate<y>? yes
Inode table for group 267 is not in group. (block 2616321653)
Relocate<y>? no
Group descriptor 267 checksum is 0x72bb, should be 0xc66c. FIXED.
Block bitmap for group 268 is not in group. (block 3197564106)
Relocate<y>? yes
Inode bitmap for group 268 is not in group. (block 1173679527)
Relocate<y>? yes
Inode table for group 268 is not in group. (block 3081059840)
Relocate<y>? no
Group descriptor 268 checksum is 0xee4e, should be 0x6c67. FIXED.
Block bitmap for group 269 is not in group. (block 467880860)
Relocate<y>? yes
Inode bitmap for group 269 is not in group. (block 3461842583)
Relocate<y>? yes
Inode table for group 269 is not in group. (block 903401461)
Relocate<y>? no
Group descriptor 269 checksum is 0x701d, should be 0x1735. FIXED.
Block bitmap for group 270 is not in group. (block 1737084563)
Relocate<y>? yes
Inode bitmap for group 270 is not in group. (block 1617385180)
Relocate<y>? yes
Inode table for group 270 is not in group. (block 3944519733)
Relocate<y>? no
Group descriptor 270 checksum is 0x1c78, should be 0x9f4e. FIXED.
Block bitmap for group 271 is not in group. (block 3558332121)
Relocate<y>? yes
Inode bitmap for group 271 is not in group. (block 1481837154)
Relocate<y>? yes
Inode table for group 271 is not in group. (block 1108213120)
Relocate<y>? no
Group descriptor 271 checksum is 0x3066, should be 0xce01. FIXED.
Block bitmap for group 272 is not in group. (block 3294840462)
Relocate<y>? yes
Inode bitmap for group 272 is not in group. (block 1680662834)
Relocate<y>? yes
Inode table for group 272 is not in group. (block 747037043)
Relocate<y>? no
Group descriptor 272 checksum is 0x7d96, should be 0xde7a. FIXED.
Block bitmap for group 273 is not in group. (block 805709209)
Relocate<y>? cancelled!
Inode bitmap for group 273 is not in group. (block 220354588)
Inode table for group 273 is not in group. (block 281430039)
Group descriptor 273 checksum is 0xa378, should be 0x6f41. FIXED.
/dev/sdb1: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sdb1: ********** WARNING: Filesystem still has errors **********And some other commands I tried:
$ sudo parted /dev/sdb p
Model: ATA Hitachi HTS54757 (scsi)
Disk /dev/sdb: 750GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 684GB 684GB primary ext4 boot
2 684GB 750GB 66.0GB primary ext4Code: Select all
$ sudo dumpe2fs /dev/sdb1 | grep superblock
dumpe2fs 1.42.8 (20-Jun-2013)
dumpe2fs: Invalid argument while reading journal super blockCode: Select all
# sudo mount /dev/loop1 -t ext4 -o ro,offset=32256 /home/juha/diskimage/
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.Code: Select all
$ sudo mount -t ext4 -o ro,offset=32256 /dev/sdb /mnt/Disk_D
mount: wrong fs type, bad option, bad superblock on /dev/loop0,1 /home/juha/diski
$ dmesg | tail
[ 873.975814] loop: module loaded
[ 902.247136] CE: hpet increased min_delta_ns to 20113 nsec
[ 1090.928745] EXT4-fs (loop1): VFS: Can't find ext4 filesystem
[ 1224.940931] EXT4-fs (loop0): VFS: Can't find ext4 filesystem
[ 477.255509] EXT4-fs (sdb1): VFS: Can't find ext4 filesystemHere is some output from testdisk while doing deepsearch on partition:
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63
P ext4 0 32 33 83175 145 42 1336213504
P ext4 83175 145 43 91201 52 51 128931840
Write isn't available because the partition table type "None" has been selected.
ext4 0 32 31 83175 145 40 1336213504
Warning: number of heads/cylinder mismatches 64 (FAT) != 255 (HD)
FAT12 20 89 2 20 206 12 7382 [GParted-EFI]
ext4 0 32 33 83175 145 42 1336213504Code: Select all
kpartx -lv /dev/sdb
sdb1 : 0 1336213504 /dev/sdb 2048
sdb2 : 0 128931840 /dev/sdb 1336215552I would really appreciate some help here.
I had online backup of ~10 GB of the most important data of it, but there still is on this lost partition at least another 10-20 GB of really vital data, the loss of which would be quite a blow.
