please help:-(....please
vasen
#1 Post by vasen »
My linux system failed to boot due to the damaged file system i think.i booted with live cd and tried test disk and was only to recover 1.8gb of data....does not show rest of hard drive.
fdisk -l
Disk /dev/sda: 750.2 GB, 750156374016 bytes
255 heads, 63 sectors/track, 91201 cylinders, total 1465149168 sectors
Disk identifier: 0x000137e7
Device Boot Start End Blocks Id System
/dev/sda1 * 63 208844 104391 83 Linux
Partition 1 does not start on physical sector boundary.
/dev/sda2 208845 1465144064 732467610 8e Linux LVM
Partition 2 does not start on physical sector boundary.
Disk /dev/mapper/VolGroup00-LogVol00: 744.5 GB, 744539291648 bytes
1 heads, 1 sectors/track, 1454178304 cylinders, total 1454178304 sectors
Alignment offset: 1536 bytes
Disk identifier: 0x00000000
>Disk /dev/sda - 750 GB / 698 GiB - WDC WD7500AZRX-00A8LB0
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA MK1059GSM
Disk /dev/mapper/VolGroup00-LogVol00 - 744 GB / 693 GiB - WDC WD7500AZRX-00A8LB0
Disk /dev/mapper/VolGroup00-LogVol01 - 5502 MB / 5248 MiB - WDC WD7500AZRX-00A8LB0
Disk /dev/sr0 - 734 MB / 700 MiB (RO) - HL-DT-ST DVDRAM GH24NS90
Disk /dev/dm-0 - 744 GB / 693 GiB - WDC WD7500AZRX-00A8LB0
Disk /dev/dm-1 - 5502 MB / 5248 MiB - WDC WD7500AZRX-00A8LB0
[Intel ] Intel/PC partition
[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
[Humax ] Humax partition table
[Mac ] Apple partition map
>[None ] Non partitioned media
[Sun ] Sun Solaris partition
[XBox ] XBox partition
Hint: None partition table type has been detected.
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a drive to be 'Non-partitioned'.
part i was able to recover:
disk /dev/mapper/VolGroup00-LogVol00 - 744 GB / 693 GiB - 1454178304 sectors
P ext3 0 1454178303 1454178304
i am unable to recover---need help
Disk /dev/mapper/VolGroup00-LogVol00 - 744 GB / 693 GiB - 1454178304 sectors
1 * Linux 548798912 688823795 140024884
