Retrieving deleted file (That I know where is...)
Froglegs7162
#1 Post by Froglegs7162 »
Hello
I've been following a guide for android to recover lost data. I have a raw disk file now, and I've found the files I want to recover with testdisk.
testdisk cmd
testdisk cmd
However, when I tried using "advanced" in testdisk, it just prompted me to make an image file from the partition or whatever it was. There was no "undelete" option. Also, when I try to just copy the file into my computer it doesnt show up (naturally... As it is deleted I guess).
I also tried using photorec but I'm fairly sure it didn't find the files when I looked through the jpgs it had found, even though it found quite a lot.
Help is much appreciated!! So much work just to get a single picture recovered :?
Re: Retrieving deleted file (That I know where is...)
Use 'c' to copy your deleted file
