TestDisk shows XBOX FATX partition
Induna123
#1 Post by Induna123 »
I've been using TestDisk to analyse all my hard drives to make sure they are correct and one of them came up as XBOX instead of Intel which surprised me as I have Windows XP installed on it. Thinking back I may have used this drive in an XBOX (the first one) and then took it out to use it back on the PC.
Just out of curiosity I took another hard drive out of the XBOX and connected it to the PC and it wouldn't show up in Windows XP. Apparently I need to unlock the drive before I can use it for the PC.
Two questions, how did I manage to format it with NTFS and install WinXP on it without unlocking it and how do I get it to show up correctly as Intel NTFS rather than XBOX FATX? There must be a file somewhere on the drive that making it report this.
Here's the log
Tue Dec 10 14:10:34 2013
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=122941242880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250999111168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=122941242880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250999111168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=10618804224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=112316166144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=13982943744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=237011410944
Disk /dev/sda - 122 GB / 114 GiB - CHS 14946 255 63, sector size=512 - Maxtor 6Y120P0, S/N:335958325a504533202020202020202020202020, FW:YAR41BW0
Disk /dev/sdb - 250 GB / 233 GiB - CHS 30515 255 63, sector size=512 - Maxtor 6L250R0, S/N:354c433135444754202020202020202020202020, FW:BAJ41G20
Partition table type (auto): XBox
Disk /dev/sda - 122 GB / 114 GiB - Maxtor 6Y120P0
Partition table type: XBox
Analyse Disk /dev/sda - 122 GB / 114 GiB - CHS 14946 255 63
check_part_xbox failed for partition type 01
Invalid FATX signature
 1 P FATX                     0  16 17    95 172 13    1536000
 2 P FATX                    95 172 14   191  73 10    1536000
 3 P FATX                   191  73 11   286 229  7    1536000
 4 P FATX                   286 229  8   350 163  5    1024000
 5 P FATX                   350 163  6 14946 192 29  234486591
NTFS at 0/1/1
filesystem size           20739852
sectors_per_cluster       8
mftmirr_lcn               667140
clusters_per_mft_record   -10
NTFS part_offset=32256, part_size=10618804224, sector_size=512
NTFS at 0/1/1
mftmirr_lcn               667140
     Unknown                  0   1  1  1290 254 63   20739852
     NTFS, blocksize=4096, 10618 MB / 10126 MiB
Partition not added.
Re: TestDisk shows XBOX FATX partition
When TestDisk starts, override the XBOX partition table type and choose PC/Intel instead.
If you really want to remove the old XBOX partition table signature, I can modify TestDisk to do it.
Induna123
#3 Post by Induna123 »
Well if it's not too much trouble then yes :)
