the bottom info how the disk used to be.
Thu Apr 19 08:26:51 2012
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
OS: Windows XP SP3
Compilation date: 2012-03-25T21:26:26
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=21476173824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=228572273664
filewin32_getfilesize(\\.\F:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=750153729024
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - SAMSUNG SP2514N, S/N:30534238314a5930343933313735202020202020, FW:VF100-33
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKB-00YSA0, FW:12.01C02
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Promise 1+0 JBOD, FW:1.10
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Promise 1+0 JBOD, FW:1.10
Disk /dev/sde - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Promise 1+0 JBOD, FW:1.10
Disk /dev/sdb - 500 GB / 465 GiB - WDC WD5000AAKB-00YSA0
NTFS at 0/1/1
 1 * HPFS - NTFS              0   1  1  2610 254 63   41945652 [SOURCE]
 2 E extended LBA          2611   0  1 30399 254 63  446430285
test_logical:
Ask the user for vista mode
search_vista_part: 0
NTFS at 0/1/1
filesystem size           41945652
sectors_per_cluster       8
mftmirr_lcn               2621603
clusters_per_mft_record   -10
     NTFS, 21 GB / 20 GiB
NTFS at 0/1/1
mftmirr_lcn               2621603
NTFS at 2610/254/63
mftmirr_lcn               2621603
     NTFS found using backup sector!, 21 GB / 20 GiB
NTFS at 60800/254/63
mftmirr_lcn               601
     HPFS - NTFS          58190   1  1 60800 254 63   41945652
file_pread(5,8,buffer,976773261(60801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773261(60801/82/31)) lseek err Invalid argument
file_pread(5,8,buffer,976773389(60801/84/33)) lseek err Invalid argument
file_pread(5,8,buffer,976773517(60801/86/35)) lseek err Invalid argument
file_pread(5,8,buffer,976773645(60801/88/37)) lseek err Invalid argument
file_pread(5,8,buffer,976773773(60801/90/39)) lseek err Invalid argument
file_pread(5,8,buffer,976773901(60801/92/41)) lseek err Invalid argument
file_pread(5,8,buffer,976774029(60801/94/43)) lseek err Invalid argument
file_pread(5,8,buffer,976774157(60801/96/45)) lseek err Invalid argument
file_pread(5,8,buffer,976774285(60801/98/47)) lseek err Invalid argument
file_pread(5,8,buffer,976774413(60801/100/49)) lseek err Invalid argument
file_pread(5,8,buffer,976774541(60801/102/51)) lseek err Invalid argument
file_pread(5,8,buffer,976774669(60801/104/53)) lseek err Invalid argument
file_pread(5,8,buffer,976774797(60801/106/55)) lseek err Invalid argument
file_pread(5,8,buffer,976774925(60801/108/57)) lseek err Invalid argument
file_pread(5,8,buffer,976775053(60801/110/59)) lseek err Invalid argument
file_pread(5,8,buffer,976775181(60801/112/61)) lseek err Invalid argument
file_pread(5,8,buffer,976775309(60801/114/63)) lseek err Invalid argument
file_pread(5,8,buffer,976775437(60801/117/2)) lseek err Invalid argument
file_pread(5,8,buffer,976775565(60801/119/4)) lseek err Invalid argument
file_pread(5,8,buffer,976775693(60801/121/6)) lseek err Invalid argument
file_pread(5,8,buffer,976775821(60801/123/8)) lseek err Invalid argument
file_pread(5,8,buffer,976775949(60801/125/10)) lseek err Invalid argument
file_pread(5,8,buffer,976776077(60801/127/12)) lseek err Invalid argument
file_pread(5,8,buffer,976776205(60801/129/14)) lseek err Invalid argument
file_pread(5,8,buffer,976776333(60801/131/16)) lseek err Invalid argument
file_pread(5,8,buffer,976776461(60801/133/18)) lseek err Invalid argument
file_pread(5,2,buffer,976783377(60801/243/4)) lseek err Invalid argument
file_pread(5,2,buffer,976783440(60801/244/4)) lseek err Invalid argument
file_pread(5,2,buffer,976783503(60801/245/4)) lseek err Invalid argument
file_pread(5,1,buffer,976784129(60801/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,976784130(60802/0/1)) lseek err Invalid argument
   L HPFS - NTFS          58190   1  1 60800 254 63   41945652
add_ext_part_i386: max
add_ext_part_i386: min
 2 E extended LBA         58190   0  1 60800 254 63   41945715
 5 L HPFS - NTFS          58190   1  1 60800 254 63   41945652
 2 E extended LBA          2611   0  1 60800 254 63  934822350
write_all_log_i386: CHS: 58190/0/1,lba=934822350
Thank you and best regards.
