Help - Drive too small / partition ends after disk limits Topic is solved
sicae
#1 Post by sicae »
I'm trying to fix a friend's external hard drive (Samsung STORY Station). She says that she unplugged it while it was still operating, and now appears as RAW in Windows Disk Management.
I ran TestDisk on it, hoping it was an easy fix, but no luck. It finds the partition I'm looking for, but I get the following errors:
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4000 GB / 3726 GiB)
HPFS - NTFS 243201 1 2 486401 254 63 3907024001
and
This partition ends after the disk limits. (start=3907024129, size=3907024001, end=3519080833, disk end=3907029168)
I've tried searching through the forums, and I've Googled to no end, but I can't figure out what to do about it..
The closest I've come, is thinking that I could do the same thing as they did in this post, but I'm really not sure.
My full TestDisk log is posted below.
Any help is greatly appreciated..
Greetings,
Diego
Thu Apr  5 23:59:49 2012
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
OS: Windows XP SP3
Compilation date: 2012-03-25T21:26:26
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=500118585344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000215674880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=500118585344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000215674880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=100027597824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202241024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=200038809600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=200047034880
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63, sector size=512 - Promise 2+0 Stripe/RAID0, FW:1.10
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121602 255 63, sector size=512 - VIA SATA  RAID 0
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung STORY Station
Disk /dev/sdc - 2000 GB / 1863 GiB - Samsung STORY Station
Ask the user for vista mode
search_vista_part: 1
BAD_RS LBA=3907024129 64
file_pread(6,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(6,7,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(6,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(6,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(6,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(6,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(6,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(6,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
NTFS at 243200/254/63
filesystem size           3907024001
sectors_per_cluster       8
mftmirr_lcn               244189000
clusters_per_mft_record   -10
     HPFS - NTFS              0   1  2 243200 254 63 3907024001 [TESWOUT USB BOX]
     NTFS found using backup sector!, 2000 GB / 1863 GiB
file_pread(6,8,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(6,8,buffer,3907029312(243201/83/19)) lseek err Invalid argument
file_pread(6,8,buffer,3907029440(243201/85/21)) lseek err Invalid argument
file_pread(6,8,buffer,3907029568(243201/87/23)) lseek err Invalid argument
file_pread(6,8,buffer,3907029696(243201/89/25)) lseek err Invalid argument
file_pread(6,8,buffer,3907029824(243201/91/27)) lseek err Invalid argument
file_pread(6,8,buffer,3907029952(243201/93/29)) lseek err Invalid argument
file_pread(6,8,buffer,3907030080(243201/95/31)) lseek err Invalid argument
file_pread(6,8,buffer,3907030208(243201/97/33)) lseek err Invalid argument
file_pread(6,8,buffer,3907030336(243201/99/35)) lseek err Invalid argument
file_pread(6,8,buffer,3907030464(243201/101/37)) lseek err Invalid argument
file_pread(6,8,buffer,3907030592(243201/103/39)) lseek err Invalid argument
file_pread(6,8,buffer,3907030720(243201/105/41)) lseek err Invalid argument
file_pread(6,8,buffer,3907030848(243201/107/43)) lseek err Invalid argument
file_pread(6,8,buffer,3907030976(243201/109/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
   L HPFS - NTFS              0   1  2 243200 254 63 3907024001 [TESWOUT USB BOX]
add_ext_part_i386: max
add_ext_part_i386: min
 1 E extended LBA             0   1  1 243200 254 63 3907024002
 5 L HPFS - NTFS              0   1  2 243200 254 63 3907024001 [TESWOUT USB BOX]
write_all_log_i386: CHS: 0/1/1,lba=63
remy
Re: Help - Drive too small / partition ends after disk limit
#2 Post by remy »
The partition you show could'nt be the good one. It's beggining at the end of the disk.
Are you sure the good one would'nt be this one ?
#3 Post by Fiona »
Your partition table is empty.
But Deeper Search found your Partition.
Currently it's displayed as logical partition and should be primary.
The geometry is wrong.
The value 2 at the beginning of your partition should be 1.
Please run Deeper Search.
If your partition is found, press p to have a try to list your files.
Do you see your data or an error message?
Only if your your data are listed, recover your partition (if your data are not listed, please let me know).;
Use your left or right arrow key on your keyboard to set it to P for primary.
You can see it at the left.
P HPFS - NTFS 0 1 2 243200 254 63 3907024001 [TESWOUT USB BOX]
Press enter, check Write and confirm it with enter and y.
You'll get a message about boot sector recovery, that your boot sector is bad and its backup is OK.
Confirm at Backup BS with enter and y.
Close TestDisk using Quit.
Restart your PC.
sicae
#4 Post by sicae »
Thank you for the prompt replies.
I will obediently follow all steps, and return to the forum once TestDisk is done scanning and I've taken above mentioned steps (taking care that it does indeed list my files)!
Diego
sicae
#5 Post by sicae »
Just wanted to thank you all for the rapid response.
Fiona's instructions worked like a charm. The hard drive is working again, 100% error-free.
I am honestly amazed (happily so) at the level of (expert) support available for TestDisk (and PhotoRec), both free products..
Very much appreciated!
Gr,
Diego
