TestDisk Scan and deeper scan show no partitions found.
I would like to recover the partition table and file system of drive L:, but I don't know how to proceed given the errors logged below. The log shows both the bad (L:) and the good (M:) drives, for reference. Windows disk manager shows the L: drive as correct size and "healthy" but "RAW". FYI, both 300GB eSATA drives are connected to a Thermaltake BlackXDuet (dual drive) external USB device via a common USB 3.0 cable.
Log follows. I think I interrupted the scan in this run, because it took a long time the first time, and I forgot to turn on logging before I ran it. I can re-run both scan and deeper scan again with logging on if still required, but the first time they showed no partitions found.
Thu Dec 19 09:17:40 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=14909440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=14909440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=238313013248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=14880256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=300066799616
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=10485760000
Disk /dev/sda - 250 GB / 232 GiB - CHS 32301 240 63, sector size=512 - ST925041 1AS, S/N:5VG2RMMD, FW:0003
Disk /dev/sdb - 300 GB / 279 GiB - CHS 36481 255 63, sector size=512 - ST330062 2AS
Disk /dev/sdc - 300 GB / 279 GiB - CHS 36481 255 63, sector size=512 - ST330062 2AS
Disk /dev/sdd - 14 MB / 14 MiB - CHS 1 255 63, sector size=512 - RICOH R5U880FlashMedia, FW:0000
Disk /dev/sdc - 300 GB / 279 GiB - ST330062 2AS
Analyse Disk /dev/sdc - 300 GB / 279 GiB - CHS 36481 255 63
Geometry from i386 MBR: head=115 sector=52
BAD_RS LBA=1936269394 5382406
check_part_i386 1 type 4F: no test
BAD_RS LBA=1917848077 5967333
check_part_i386 2 type 73: no test
BAD_RS LBA=1818575915 5855017
check_part_i386 3 type 2B: no test
BAD_RS LBA=2844524554 5982593
check_part_i386 4 type 61: no test
1 * Sys=4F 120527 49 53 234813 237 34 1836016416
Bad relative sector.
2 * Sys=73 119380 132 62 153270 41 37 544437093
3 * Sys=2B 113201 29 24 147074 114 59 544175136
4 * SpeedStor 177063 118 26 177066 225 63 54974
file_pread(6,1,buffer,586074111(36481/108/43)) lseek err Invalid argument
file_pread(6,1,buffer,586074112(36481/108/44)) lseek err Invalid argument
file_pread(6,14,buffer,586074113(36481/108/45)) lseek err Invalid argument
file_pread(6,3,buffer,586074127(36481/108/59)) lseek err Invalid argument
file_pread(6,3,buffer,586074174(36481/109/43)) lseek err Invalid argument
file_pread(6,8,buffer,586074190(36481/109/59)) lseek err Invalid argument
file_pread(6,11,buffer,586074237(36481/110/43)) lseek err Invalid argument
file_pread(6,2,buffer,586076159(36481/141/12)) lseek err Invalid argument
Disk /dev/sdb - 300 GB / 279 GiB - ST330062 2AS
Analyse Disk /dev/sdb - 300 GB / 279 GiB - CHS 36481 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 36481 43 42 586067968 [BobX200s_M]
NTFS at 0/32/33
filesystem size 586067968
mftmirr_lcn 2
NTFS, blocksize=4096, 300 GB / 279 GiB
file_pread(5,2,buffer,586074112(36481/108/44)) lseek err Invalid argument
file_pread(5,1,buffer,586074112(36481/108/44)) lseek err Invalid argument
file_pread(5,8,buffer,586072448(36481/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,586072448(36481/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,586072576(36481/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,586072704(36481/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,586072832(36481/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,586072960(36481/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,586073088(36481/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,586073216(36481/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,586073344(36481/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,586073472(36481/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,586073600(36481/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,586073728(36481/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,586073856(36481/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,586073984(36481/106/42)) lseek err Invalid argument
file_pread(5,1,buffer,586074111(36481/108/43)) lseek err Invalid argument
file_pread(5,14,buffer,586074113(36481/108/45)) lseek err Invalid argument
file_pread(5,3,buffer,586074127(36481/108/59)) lseek err Invalid argument
file_pread(5,3,buffer,586074174(36481/109/43)) lseek err Invalid argument
file_pread(5,8,buffer,586074190(36481/109/59)) lseek err Invalid argument
file_pread(5,11,buffer,586074237(36481/110/43)) lseek err Invalid argument
file_pread(5,2,buffer,586076159(36481/141/12)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 36481 43 42 586067968 [BobX200s_M]
1 * HPFS - NTFS 0 32 33 36481 43 42 586067968 [BobX200s_M]
