I have an Seagate 500GB external drive that suddenly crapped out on me. How do i repair (make only one partitions bootable and resolve the space conflict between the two partitions? Also, is the Netware 3.11 partition suppose to be the bootable one? any help greatly appreciated.
here is my log file:
Mon Dec 23 04:28:34 2013
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8103395328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8103363072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=4770630144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=159915893760
Disk \\.\PhysicalDrive2 - 8103 MB / 7728 MiB - CHS 985 255 63, sector size=512
Drive F: - 8103 MB / 7727 MiB - CHS 985 255 63, sector size=512
Drive H: - 4770 MB / 4549 MiB - CHS 579 255 63, sector size=512
Drive I: - 159 GB / 148 GiB - CHS 19442 255 63, sector size=512
Analyse Drive H: - 4770 MB / 4549 MiB - CHS 579 255 63
Geometry from i386 MBR: head=116 sector=52
BAD_RS LBA=218129509 5918957
check_part_i386 1 type 72: no test
BAD_RS LBA=729050177 1083631
check_part_i386 2 type 74: no test
BAD_RS LBA=168653938 1838434
1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
ext. HD showing RAW with all partitions bootable ? advice?
Re: ext. HD showing RAW with all partitions bootable ? advi
Windows affects a drive letter to a partition, so it's useless to search a partition inside a partition.
When starting TestDisk, choose the PhysicalDisk, not the drive.
It looks like not all disks are listed: be careful to start TestDisk from an administrator account.
