I would like to backup/clone/copy a failed partition to a file under Linux, and be able to reverse the process if needed. Reading the ddrescue documentation, it seems that partitions can only be copied to other partitions, and the dd documentation is ambiguous on this as well. Will this create a good backup of a my partition to a file?
>dd bs=512K if=/dev/sda /home/me/bup.dd conv=noerror
or this?
>dd bs=512K if=/dev/sda2 /home/me/bup.dd conv=noerror
Also, will it do any damage if I get the block size wrong? Thanks!
dd / ddrescue Question
Re: dd / ddrescue Question
I think I have the answer from the Arch linux wiki:
and to restore,
Basic stuff. It allows us to backup to a normal zipped file instead of buying another hard disk to clone to directly.
EDIT: Cut and pasted the wrong line! That second should be
# dd if=/dev/hda conv=sync,noerror bs=64K | gzip -c > /mnt/sda1/hda.img.gzCode: Select all
# fdisk -l /dev/hda > /mnt/sda1/hda_fdisk.infoEDIT: Cut and pasted the wrong line! That second should be
# gunzip -c /mnt/sda1/hda.img.gz | dd of=/dev/hda
