Hello All.
I have a situation where I accidentally Dban (Boot + Nuked) both my internal and external usb disk - the one being accidental and stopped after <10seconds - but still won't boot.
The PC had a single HDD partitioned into C: and D:
Deeper Search finds 3 partitions instead of 2 and only the D: drive is shown in green - the other two are shown as Deleted.
Here's the issue - the C: does not start at 1 0 0 but something like 12 24 380 - so how can I correct this and get this partition to be the boot partition?
Also if anyone can advise how you take a screenshot in this Windows Emulated Environment then that would also be interesting for me and others.
Thanks!
Recovery after Dban
Re: Recovery after Dban
Can you make a photo from your display and use low resolution jpg as a file format?Also if anyone can advise how you take a screenshot in this Windows Emulated Environment then that would also be interesting for me and others.
Then upload it using a another computer?
Ok - i managed to do PrntScn to Paint and extracted this Jpeg...
Does the Start at 12 223 20 need correcting?
Also what is the mystery partition starting at 14076 1 1?
- TestDisk2.JPG (61.66 KiB) Viewed 14289 times
When I use the <> keys to change the first partition to * bootable a warning comes up at the bottom in red saying:
Structure: Bad.
Structure: Bad.
Ok here are two more screenshots to compare -
- This shows what TestDisk thinks is OK with ? a bootable Primary and a separate Primary Partition?
- TestDisk3b.JPG (60.65 KiB) Viewed 14285 times
- This shows what I thought the structure should be... with bootable primary and logical partitions
- TestDisk3a.JPG (65.76 KiB) Viewed 14285 times
Thanks for your Infos!
To exactly judge your situation, I would need a screenshot from Analyse (current partition structur).
It displays your partition table.
It looks like that you're using Win7?
Dban probably caught your first 100 MB System Reserved-Partition?
That's why you can't boot.
This partition is not available anymore.
This partition contains your boot files and must be primary active.
It's a normal NTFS-partition but it has no drive letter, so that user can't access this partition and change it.
This behavior is on purpose.
Would it be possible that TestDisk found your partition without lable, based on any remnants?
In this case, you can ignore it!
You can use Deeper Search in TestDisk to have a look does TestDisk find your system reserved partition?
If TestDisk finds a required partition, you can press F to go to the end of that partition, so TestDisk will have a look for the next one.
Your screen;
http://forum.cgsecurity.org/phpBB3/down ... php?id=332
It looks like that TestDisk found both important partitions
That Windows Reserved Partition should be active and listed with a Star at the left (currently not available).
Please change your HP-Partition to P for primary only.
Your Factory_Image-partition is correct and doesn't require any action.
There might be another possibility to get your system bootable again.
I assume, that both partitions, HP and Factory_Image are correct and there is nothing to do, but to get your system bootable again.
Please start from your Win7-CD into your System Recovery Options.
Have a try to use Startup Repair.
Probably it creates another partition?
Your screen;
Hi Fiona thanks for that.
Yes it's a Windows 7 machine.
The first image download/file.php?id=330 is the result of the Deeper Search.
(Doing the Quick Search only brings up the [Factory Image] Partition)
When you said
Also I'm finding that any wrong press and I have to go through the Analyse process again taking around 1 1/2 hours!!
Nick
When you said
I don't see an option F listed?TestDisk finds a required partition, you can press F to go to the end of that partition, so TestDisk will have a look for the next one.
Nick
Are you referring to the partition with the red arrow here?Would it be possible that TestDisk found your partition without lable, based on any remnants?
- TestDisk3b.JPG (93.36 KiB) Viewed 14279 times
Yes I referred to this partition.Are you referring to the partition with the red arrow here?
Looks like that this partition was only recognized based on remnants and should be ignored.
If TestDisk finds more partitions using Deeper Search, it will list all recoverable partitions (using their size).
If a partition ends after disk limit, TestDisk diplays a message, that it can't be recovered.
If partitions overlap you must decide to set one partition to primary, logical or primary active for recovery using your right or left arrow key on your keyboard.
That's easily depend on, two partitions cannot use the same space.
There is nothing listed, but pressing F on your keyboard does it.I don't see an option F listed?
Unfortunately it's supported first since version 6.14 beta.
You're using version 6.13.
It happens to partitions when they overlap.When I use the <> keys to change the first partition to * bootable a warning comes up at the bottom in red saying:
Structure: Bad.
For example a logical partitions lies in an extended partition.
An extended partition doesn't appear in Quick nor Deeper Search but at the menu Write, where you write your complete partition structur.
An extended partition requires some space, so partitions overlap.
That's why you've got this message.
Did you check your partitions HP and Factory_Image and did you press p (on your keyboard) to list your files?
Please let me know, did you see your data or an error message.
It provides infos about the condition of your file system.
A corrupt or damaged file system is different.
Also your partition HP was found using a backup of the boot sector.
So it might be possible that dban caught that partition also?
Hopefully not.
Can you check that partition after Deeper Search and press p to list your files?
You can press q for quit to get back to the previous screen.
But be careful and don't loose your Deeper Search anymore.
It's easily intended to get out of the menu List to list your data.
If you've seen your data;
Check your partition HP.
Use your right or left arrow to set it to P for primary only..
Check your partition Factory_Image and set it to P for primary also.
Ignore that partition without label and keep it as D for deleted.
Then press Enter to proceed.
Check Write and press anter and y, to write your partitions into the partition table.
The boot sector of your HP-partition is damaged.
That's why the menu Advanced appears and offers you to repair the boot sector.
Please confirm there using Backup BS.
This will copy the backup of the boot sector over your boot sector.
Then it should be repaired.
Close TestDisk using Quit and restart.
Of course your Windows can't restart, because your boot partition is not there anymore.
Try this one like I already described;
If everything works right, you should be able to boot into your Windows again.There might be another possibility to get your system bootable again.
