Hi all, please excuse my amateurish and pathetic computer skills. I was directed to this site as a means to assist with a problem I have had with an Iomega backup HD, that I had the misfortune to purchase that uses IAB files.
I have no hardware issues at all. The problem is that once upon a time I backed up my PC hard drive in two backups one in 2006 and 2008. To cut a long story short I want the photos and videos off both versions. I do not want the system configs or other data.
I want to transfer the data on the Iomega straight to a portable HD. So I downloaded the program and started photorec and after staring at the screen for about 10 minutes trying to figure out all the numbers I realised that I was out of my depth.
After I click the photrec exe file it identifies all the drives correctly I can see the iomega and the portable HD. The thing is I don't know what will happen next if I order proceed. Anyone able to advise?
IAB Files
Re: IAB Files
You should restore your files using Iomega Automatic Backup, not using PhotoRec.
Re: IAB Files
Check the files recovered by PhotoRec, they may be your lost files.
How have you lost your files BTW ?
Re: IAB Files
This is not really a lost data issue. The Iomega contains stuff that I simply want back. Once upon a time I got a new hard disk and rather than transfer all the old crap over to the new HD from the Iomega I just got the techie to transfer it to a portable HD. I then transferred all the stuff I wanted to the new HD and deleted the contents of the portable.
In 2010 I had a HD crash lost everything and never bothered to access the stuff on the Iomega figuring I would do it another day. That day has arrived. The original Iomega software is useless for what I want to do. One website suggested I come here... I have not tried recovering anything with PhotoRec...I don't really know what I'm doing which is why I asked the question...
