I removed a drive from a RAID 1 pair, meaning to use it to install Windows on. So I deleted the ext4 partition, then created a new NTFS one. Then I deleted that as well to have a clean disk to install on.
Sometime later I managed to pretty thoroughly mung the remaining RAID drive, losing /home in the process.
Now I'd like to try to get that /home ext4 partition back on the un-RAIDed drive.
I know there's data still on the un-RAIDed drive, as I ran photorec and it found files and recovered them. Can I make this work? Is there a way to tell TestDisk what kind of filesystem to repair?
Hans
Help - ext4 partition deleted, NTFS created, then deleted
Re: Help - ext4 partition deleted, NTFS created, then delete
TestDisk would be just as long helpful as it finds your Linux (ext4) partition.
Did you already run Analyse, Quick and Deeper Search in TestDisk to see that your partition would be found?
Yes, but sadly I ran it searching for Intel partition info rather than EFI GPT. I only got wise to my error after I ran photorec and it reported finding an EFI GPT partition.
So I'll try testdisk again after I get home tonight. I was hoping to get some info on next steps and gotchas before everyone goes home for the weekend.
Thanks for the info.
Hans
Hans
ext4 + raid let me think you had a linux raid ?
If yes, probably a software based raid, so why do you thing you may had a GPT table ?
I mean : If the whole disk was raided and the raid was partitionned, i's different than if the disks were partitionned and the parts raided.
So first question is : more precision about your raid, please. Is it from a NAS or manualy made by you ?
Was it software raid, fake raid or full hardware ?
It's RAID of the mdadm variety. The system motherboard has a RAID controller on it, and there's support for RAID in the BIOS.
I wasn't the person who set up the RAID, and while I asked for the RAID to be broken (it wasn't), I wasn't the person who actually removed the secondary drive from the RAID. So I don't know if the drives were partitioned and then RAIDed, or RAIDed and then partitioned. My knowledge of the minutiae of RAID setup and configuration is minimal.
What I can tell you is that when I run a GPartEd live CD on the system, it can see the individual drives (/dev/sda etc) as well as the RAID image (/dev/md127).
This was RAID 1, so one drive is a duplicate of the other. There was only a single partition spanning the entire drive, which was (when in the raid configuration) mounted as /home.
There was another drive entirely holding the Linux filesystem root. System originally had one PATA system drive and two SATA drives, RAID 1, mounted as /home.
What makes me think it's EFI GPT is that that's what photorec reported finding when it started working on the disk.
Hans
Hans
Do you still have one disk in correct condition ? If yes, from linux liveCD and internet connection, try :
then, if no error :
(perhaps you'll need to change /dev/sda to /dev/sdb or /dev/sdc depending on your disk that is raided.
Also give feedback about :
and
We should be able to access your /home without testdisk.
sudo apt-get install mdadmCode: Select all
sudo mdadm --examine /dev/sdaAlso give feedback about :
cat /proc/mdstatCode: Select all
sudo sfdisk -luS
