.vmf files
Neox
.vmf files
#1 Post by Neox »
So I have some "maps" on my 1TB harddrive.
My problem is that .vmf isn't avaible in photorec.
Howevery when I use fidentify first on my file it says it's a Java file:
"Flatgrass.vmf: Java"
Then I thought when I tell photorec to search for Java it should find it but for some reason I can't select "Java" in photorec. The only thing I find there is "Java Class".
Now I'm not sure if I should create a custom signature or not. Can anyone help me?
