Recovering data from Toshiba TH58NVG7D2FTA20
yolbh
#1 Post by yolbh »
Hi all,
first post here so here goes...
I have a Silicone Power 16gb (i think. it may also be 32gb) flash drive which have a bad flash controller. tried to find the same dongle but it was bought a couple of years ago so couldnt find it. i then went to plan B and removed the flash device itself from the pcb ( Toshiba TH58NVG7D2FTA20) and read it entirely with Elnec programmer. so now i have a ~33GB BIN dump file whic i can see inside that there is information.
any idea how may i extract the files from it ?
does testdisk or photorec can help with that ?
Thanks a lot for any help !!
