Baron
#1 Post by Baron »
Hi everyone.
Please forgive me if my desciptions are not the best, but english is not my first language and i am not an expert on this matter.
I bought 2 months ago and external hard disk, Toshiba 1 TB, and it was working very well, till yesterday.
It never crashed, it just stopped working properly.
The computer recognize the hard disk but i cannot access in it, if i try to access an error message pop up or the computer just freeze for a little.
I downloaded TestDisk and tryed myself to adjust the problem, but i cannot solve it.
What does it means "The harddisk seems too small!" ? :?
Here the TestDisk log, i hope i have not messed up because the first time i opened TestDisk and tried to resolve i didn't used the log.
Wed Feb 5 08:49:22 2014
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1000204886016
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=30005789184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=130033419264
filewin32_getfilesize(\\.\E:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\F:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\G:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\I:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\J:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=1000203091968
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST3160021A, S/N:4a353153424a3137202020202020202020202020, FW:3.04
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA External USB 3.0
Disk /dev/sde - 1000 GB / 931 GiB - TOSHIBA External USB 3.0
Analyse Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
Info: size boot_sector 1953521072, partition 1953521664
1 * HPFS - NTFS 0 32 33 121601 57 56 1953521664 [TOSHIBA EXT]
NTFS at 0/32/33
filesystem size 1953521072
mftmirr_lcn 122095066
HPFS - NTFS 0 32 33 121601 48 31 1953521072 [TOSHIBA EXT]
file_pread(5,2,buffer,1953525168(121601/81/1)) ReadFile L'unità non riesce trovare il settore richiesto.
file_pread(5,1,buffer,1953525168(121601/81/1)) ReadFile L'unità non riesce trovare il settore richiesto.
file_pread(5,2,buffer,1953525200(121601/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953525200(121601/81/33)) lseek err Invalid argument
file_pread(5,2,buffer,1953525231(121601/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1953525231(121601/82/1)) lseek err Invalid argument
file_pread(5,2,buffer,1953525263(121601/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953525263(121601/82/33)) lseek err Invalid argument
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
NTFS at 0/32/33
BAD_RS LBA=1827604195 12965777
FAT32 LBA 113763 25 26 312838 79 29 3198143281
This partition ends after the disk limits. (start=1827604195, size=3198143281, end=730780179, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2573 GB / 2396 GiB)
NTFS at 0/32/33
$MFTMirr location mismatch or first 4 records are fragmented. Run chkdsk.
Failed to load $MFTMirr: Input/output error.
NTFS at 0/32/33
Not an exFAT boot sector.
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
filesystem size 1953521072 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 122095066 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
Status: Bad
Sectors are not identical.
NTFS at 0/32/33
NTFS at 0/32/33
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn 786432 0
Status: OK
Status: Bad
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn 786432 0
Status: OK
Status: Bad
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn 786432 0
Status: OK
Status: Bad
Please, just tell me if there is chance to recover the hard disk, i have very important data catalogued in it.
Thank you very much for your patience.
