I try recover Open Office files: odt, ods, odp, odg and a few others. I disovered that Photorec does not recover all formats from list ( http://www.cgsecurity.org/wiki/File_For ... y_PhotoRec ).
Is it any bug ? Do You have the same ?
My command:
sudo photorec /debug /log /logname photorec_log_test.txt /d media/mydisk/Recovery /cmd /dev/sdb1 fileopt,everything,disable,odt,enable,search Code: Select all
PhotoRec syntax error: odt,enable,search
