I'm new here.
Using PhotoRec i rescue most photo and movies of my gopro camera.
For the photo there aren't problem.
All the clip i rescue are not showing with any player (the play goes on sometime you can listen a noise but nothing showed on screen).
I noticed that there are two files with same duration but different resolution.
here the list of directory rescued:
18/02/2014 08.54 9.854 f4073856.jpg
18/02/2014 08.54 44.178.977 f4163776.mp4
18/02/2014 08.54 2.125.128 f4164096.mp4
18/02/2014 08.54 7.196 f4164160.jpg
18/02/2014 08.54 128.402.371 f4426880.mp4
18/02/2014 08.54 6.235.951 f4427136.mp4
18/02/2014 08.54 10.523 f4427520.jpg
18/02/2014 08.54 178.251.389 f4791872.mp4
18/02/2014 08.54 8.665.300 f4792256.mp4
18/02/2014 08.54 11.332 f4792704.jpg
18/02/2014 08.55 364.806.036 f5538560.mp4
18/02/2014 08.55 17.692.188 f5539264.mp4
18/02/2014 08.55 11.335 f5539840.jpg
18/02/2014 08.55 204.826.700 f5958592.mp4
18/02/2014 08.55 9.954.858 f5958976.mp4
18/02/2014 08.55 9.700 f5959424.jpg
18/02/2014 08.56 17.851.248 f6713024.mp4
18/02/2014 08.56 10.068 f6713600.jpg
18/02/2014 08.56 52.259.743 f6820224.mp4
18/02/2014 08.56 2.525.654 f6820416.mp4
18/02/2014 08.56 112.707.135 f7029440.mp4
18/02/2014 08.56 5.464.172 f7029696.mp4
18/02/2014 08.56 5.629 f7029824.jpg
18/02/2014 08.56 5.495.208 f7040832.mp4
18/02/2014 08.56 279.435 f7041152.mp4
18/02/2014 08.56 5.374 f7041216.jpg
18/02/2014 08.56 72.618.727 f7189696.mp4
18/02/2014 08.56 3.527.301 f7190016.mp4
18/02/2014 08.56 6.742 f7190080.jpg
18/02/2014 08.56 127.817.392 f7451392.mp4
18/02/2014 08.56 6.210.387 f7451840.mp4
18/02/2014 08.56 7.941 f7452224.jpg
18/02/2014 08.56 13.906.879 f8036992.mp4
18/02/2014 08.56 9.190 f8037504.jpg
18/02/2014 08.56 4.230.534 f8214144.mp4
18/02/2014 08.56 8.494 f8214528.jpg
18/02/2014 08.56 733.841 f8244544.mp4
18/02/2014 08.56 5.634 f8244608.jpg
18/02/2014 08.57 1.379.280 f8261312.jpg
18/02/2014 08.57 6.102 f8264384.jpg
18/02/2014 08.57 10.079.979 f8689536.mp4
18/02/2014 08.57 1.703.113 f8689856.jpg
18/02/2014 08.57 1.723.092 f8693184.jpg
18/02/2014 08.57 1.779.810 f8696576.jpg
18/02/2014 08.57 1.874.503 f8700096.jpg
18/02/2014 08.57 1.920.929 f8703808.jpg
18/02/2014 08.57 1.639.503 f8707584.jpg
18/02/2014 08.57 1.633.575 f8710848.jpg
18/02/2014 08.57 1.637.511 f8714048.jpg
18/02/2014 08.57 1.647.804 f8717248.jpg
18/02/2014 08.57 1.659.932 f8720512.jpg
18/02/2014 08.57 6.052 f8723776.jpg
18/02/2014 08.57 142.624.067 f9015552.mp4
18/02/2014 08.57 6.893.678 f9015808.mp4
18/02/2014 08.57 7.431 f9016064.jpg
18/02/2014 08.57 6.973.464 f9310016.mp4
18/02/2014 08.57 7.352 f9310144.jpg
18/02/2014 08.57 13.466.873 f9337216.mp4
18/02/2014 08.57 676.673 f9337792.mp4
18/02/2014 08.57 194 f9337920.txt
18/02/2014 08.57 13.745 f9338496.jpg
18/02/2014 08.57 2.666.104 f9450432.mp4
18/02/2014 08.57 11.272 f9450816.jpg
18/02/2014 08.57 25.678.796 f9503040.mp4
18/02/2014 08.57 1.285.889 f9503296.mp4
18/02/2014 08.57 6.229 f9503360.jpg
18/02/2014 08.57 42.398.511 f9590272.mp4
18/02/2014 08.57 2.130.016 f9590400.mp4
500 File 2.462.588.567 byte
2 Directory 879.631.998.976 byte disponibili
for example the 3 first files for me are referred to the same clip (thumbnail, low and high resolution of the same clip)
How can i merge those file in order to play it?
i can't believe i retrived all file i need but i can't manage it.
Can someone Help me?
Thank you.
GOPRO Clip Format
Re: GOPRO Clip Format
I am currently working on a solution for this problem. The original video files are fragmented / intertwined.
If you can share a disk image of the memory card or are ready so send the memory card itself, I can work on it if you want.
Thank you, i would like to share disk image (i'm italian and you are in france i guess).cgrenier wrote:I am currently working on a solution for this problem. The original video files are fragmented / intertwined.
how can i share the disk image?
Where is a "cloud" with 16gb to share it? I can have skydrive and imac cloud but i guess it's 5gb
According to you the sd card is damnaged or i can use it agnain after fortmat?
Thanks
You can use Google Drive, the limit is 15 GB.
I share the image here:cgrenier wrote:You can use Google Drive, the limit is 15 GB.
https://drive.google.com/folderview?id= ... sp=sharing
I made this image with iMac utility disk
Tell me if i have to made this with another method.
Tanks
bangkok2010
I have the same problem. Did you find a solution to it?
Well, I have a solution to recover video from latest GoPro but not a free one:
http://www.cgsecurity.org/wiki/Service_ ... nn%C3%A9es
