Partitions and drive are gone
dennis
#1 Post by dennis »
Hello Guys,
I'm in a bad situation, and in the end i figured out that it's me to blame.
I've been trying to fix my 1Tb Sony external hdd.
it dropped on the ground when i was using it, windows crashed and the drive was gone.
So i google the messages i got and figured out that it should be a big problem to
fix the disk by my self.
originaly 3 partitions: 100Mb, 550Mb and 350Mb locked partition (Sony password protection manager)
the 3rd partition is only visable when its unlocked by password protect manager)
This didn' t work any more and i start trying to fix it........
Done chkdsk /r and found one partition working again, but the first partition (100mb) disappeared after a few
checks and attempts to recover data with several recovery programs. (slow and took days to check)
even i have stopped some scans in the process due to frustration.......
googled and figured out that formatting the first partition was my only option.........STUPID........
than all the partitions were gone and it showed up as a bad disk.
again google the messages and found Testdisk...........too late unfortunate..... i learned now....
i run test disk and get the same results as my last tries with different programs by keep on trying to get it fixed.
at this stage i'm on the edge and might make things worse than better.
Can somebody advice me what to do, please find below log of test disk, (A LOT OF ERRORS....... i even had to take out a lot of them ''Your message contains 85538 characters. The maximum number of allowed characters is 60000''. )
Wed Feb 26 16:29:07 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000204884480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204884480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=161375846400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=338625036288
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BD142, S/N:202020202020202020202020335a4b5432385050, FW:KC47
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Sony Hard Drive, FW:0201
Disk /dev/sdb - 1000 GB / 931 GiB - Sony Hard Drive
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48(0/0/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,95(0/1/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,111(0/1/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,158(0/2/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2080(0/33/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,51(0/0/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98(0/1/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,119(0/1/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,169(0/2/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2082(0/33/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,63(0/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,79(0/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,126(0/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,142(0/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,189(0/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2111(0/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,1008(0/16/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1024(0/16/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1071(0/17/1)) ReadFile Incorrect function.
file_pread(5,16,buffer,3056(0/48/33)) ReadFile Incorrect function.
file_pread(5,1,buffer,3056(0/48/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,1074(0/17/4)) ReadFile Incorrect function.
file_pread(5,16,buffer,3119(0/49/33)) ReadFile Incorrect function.
file_pread(5,1,buffer,3119(0/49/33)) ReadFile Incorrect function.
file_pread(5,16,buffer,4096(0/65/2)) ReadFile Incorrect function.
file_pread(5,1,buffer,4096(0/65/2)) ReadFile Incorrect function.
file_pread(5,15,buffer,4097(0/65/3)) ReadFile Incorrect function.
file_pread(5,3,buffer,4112(0/65/18)) ReadFile Incorrect function.
file_pread(5,3,buffer,4159(0/66/2)) ReadFile Incorrect function.
file_pread(5,8,buffer,4175(0/66/18)) ReadFile Incorrect function.
file_pread(5,11,buffer,4222(0/67/2)) ReadFile Incorrect function.
file_pread(5,16,buffer,6146(0/97/36)) ReadFile Incorrect function.
file_pread(5,1,buffer,6152(0/97/42)) ReadFile Incorrect function.
file_pread(5,7,buffer,6153(0/97/43)) ReadFile Incorrect function.
file_pread(5,16,buffer,6223(0/98/50)) ReadFile Incorrect function.
file_pread(5,1,buffer,6223(0/98/50)) ReadFile Incorrect function.
file_pread(5,11,buffer,6270(0/99/34)) ReadFile Incorrect function.
file_pread(5,2,buffer,8192(0/130/3)) ReadFile Incorrect function.
file_pread(5,14,buffer,8194(0/130/5)) ReadFile Incorrect function.
file_pread(5,3,buffer,8208(0/130/19)) ReadFile Incorrect function.
file_pread(5,3,buffer,8255(0/131/3)) ReadFile Incorrect function.
file_pread(5,8,buffer,8271(0/131/19)) ReadFile Incorrect function.
file_pread(5,11,buffer,8318(0/132/3)) ReadFile Incorrect function.
file_pread(5,2,buffer,10240(0/162/35)) ReadFile Incorrect function.
file_pread(5,14,buffer,10242(0/162/37)) ReadFile Incorrect function.
file_pread(5,3,buffer,10256(0/162/51)) ReadFile Incorrect function.
file_pread(5,3,buffer,10303(0/163/35)) ReadFile Incorrect function.
file_pread(5,8,buffer,10319(0/163/51)) ReadFile Incorrect function.
file_pread(5,11,buffer,10366(0/164/35)) ReadFile Incorrect function.
file_pread(5,2,buffer,12288(0/195/4)) ReadFile Incorrect function.
file_pread(5,14,buffer,12290(0/195/6)) ReadFile Incorrect function.
file_pread(5,3,buffer,12304(0/195/20)) ReadFile Incorrect function.
file_pread(5,3,buffer,12351(0/196/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,12367(0/196/20)) ReadFile Incorrect function.
file_pread(5,11,buffer,12414(0/197/4)) ReadFile Incorrect function.
file_pread(5,2,buffer,14336(0/227/36)) ReadFile Incorrect function.
file_pread(5,14,buffer,14338(0/227/38)) ReadFile Incorrect function.
file_pread(5,16,buffer,14399(0/228/36)) ReadFile Incorrect function.
file_pread(5,1,buffer,14399(0/228/36)) ReadFile Incorrect function.
file_pread(5,8,buffer,14415(0/228/52)) ReadFile Incorrect function.
file_pread(5,11,buffer,14462(0/229/36)) ReadFile Incorrect function.
file_pread(5,16,buffer,15120(0/240/1)) ReadFile Incorrect function.
file_pread(5,1,buffer,15120(0/240/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,15128(0/240/9)) ReadFile Incorrect function.
file_pread(5,3,buffer,15136(0/240/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,15183(0/241/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,15199(0/241/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,15246(0/242/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,17168(1/17/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,15186(0/241/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,15262(0/242/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,15309(0/243/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,17231(1/18/33)) ReadFile Incorrect function.
file_pread(5,16,buffer,16128(1/1/1)) ReadFile Incorrect function.
file_pread(5,1,buffer,16128(1/1/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,16144(1/1/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,16191(1/2/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,18113(1/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,16129(1/1/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16207(1/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16254(1/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,18176(1/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,16384(1/5/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16400(1/5/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16447(1/6/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16463(1/6/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16510(1/7/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,18432(1/37/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,18434(1/37/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,18495(1/38/37)) ReadFile Incorrect function.
file_pread(5,16,buffer,18511(1/38/53)) ReadFile Incorrect function.
file_pread(5,1,buffer,18511(1/38/53)) ReadFile Incorrect function.
file_pread(5,11,buffer,18558(1/39/37)) ReadFile Incorrect function.
file_pread(5,16,buffer,20482(1/70/8)) ReadFile Incorrect function.
file_pread(5,16,buffer,20496(1/70/22)) ReadFile Incorrect function.
file_pread(5,1,buffer,20496(1/70/22)) ReadFile Incorrect function.
file_pread(5,16,buffer,20559(1/71/22)) ReadFile Incorrect function.
file_pread(5,1,buffer,20559(1/71/22)) ReadFile Incorrect function.
file_pread(5,16,buffer,22528(1/102/38)) ReadFile Incorrect function.
file_pread(5,1,buffer,22528(1/102/38)) ReadFile Incorrect function.
file_pread(5,15,buffer,22529(1/102/39)) ReadFile Incorrect function.
file_pread(5,3,buffer,22544(1/102/54)) ReadFile Incorrect function.
file_pread(5,3,buffer,22591(1/103/38)) ReadFile Incorrect function.
file_pread(5,8,buffer,22607(1/103/54)) ReadFile Incorrect function.
file_pread(5,11,buffer,22654(1/104/38)) ReadFile Incorrect function.
file_pread(5,2,buffer,24576(1/135/7)) ReadFile Incorrect function.
file_pread(5,14,buffer,24578(1/135/9)) ReadFile Incorrect function.
file_pread(5,3,buffer,24592(1/135/23)) ReadFile Incorrect function.
file_pread(5,3,buffer,24639(1/136/7)) ReadFile Incorrect function.
file_pread(5,8,buffer,24655(1/136/23)) ReadFile Incorrect function.
file_pread(5,11,buffer,24702(1/137/7)) ReadFile Incorrect function.
file_pread(5,2,buffer,26624(1/167/39)) ReadFile Incorrect function.
file_pread(5,14,buffer,26626(1/167/41)) ReadFile Incorrect function.
file_pread(5,3,buffer,26640(1/167/55)) ReadFile Incorrect function.
file_pread(5,3,buffer,26687(1/168/39)) ReadFile Incorrect function.
file_pread(5,8,buffer,26703(1/168/55)) ReadFile Incorrect function.
file_pread(5,11,buffer,26750(1/169/39)) ReadFile Incorrect function.
file_pread(5,2,buffer,28672(1/200/8)) ReadFile Incorrect function.
file_pread(5,14,buffer,28674(1/200/10)) ReadFile Incorrect function.
file_pread(5,16,buffer,28735(1/201/8)) ReadFile Incorrect function.
file_pread(5,1,buffer,28736(1/201/9)) ReadFile Incorrect function.
file_pread(5,8,buffer,28751(1/201/24)) ReadFile Incorrect function.
file_pread(5,16,buffer,30736(1/232/56)) ReadFile Incorrect function.
file_pread(5,16,buffer,30783(1/233/40)) ReadFile Incorrect function.
file_pread(5,1,buffer,30783(1/233/40)) ReadFile Incorrect function.
file_pread(5,8,buffer,30799(1/233/56)) ReadFile Incorrect function.
file_pread(5,11,buffer,30846(1/234/40)) ReadFile Incorrect function.
file_pread(5,11,buffer,96516(6/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98438(6/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,96456(6/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,96532(6/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,96579(6/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98501(6/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,112597(7/2/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,112644(7/3/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,114566(7/33/33)) ReadFile Incorrect function.
file_pread(5,14,buffer,112642(7/2/62)) ReadFile Incorrect function.
file_pread(5,3,buffer,112656(7/3/13)) ReadFile Incorrect function.
file_pread(5,3,buffer,112703(7/3/60)) ReadFile Incorrect function.
file_pread(5,8,buffer,112719(7/4/13)) ReadFile Incorrect function.
file_pread(5,11,buffer,112766(7/4/60)) ReadFile Incorrect function.
file_pread(5,2,buffer,114688(7/35/29)) ReadFile Incorrect function.
file_pread(5,14,buffer,114690(7/35/31)) ReadFile Incorrect function.
file_pread(5,3,buffer,114704(7/35/45)) ReadFile Incorrect function.
file_pread(5,3,buffer,114751(7/36/29)) ReadFile Incorrect function.
file_pread(5,8,buffer,114767(7/36/45)) ReadFile Incorrect function.
file_pread(5,11,buffer,114814(7/37/29)) ReadFile Incorrect function.
file_pread(5,2,buffer,116736(7/67/61)) ReadFile Incorrect function.
file_pread(5,14,buffer,116738(7/67/63)) ReadFile Incorrect function.
file_pread(5,3,buffer,116752(7/68/14)) ReadFile Incorrect function.
file_pread(5,3,buffer,116799(7/68/61)) ReadFile Incorrect function.
file_pread(5,8,buffer,116815(7/69/14)) ReadFile Incorrect function.
file_pread(5,11,buffer,116862(7/69/61)) ReadFile Incorrect function.
file_pread(5,2,buffer,118784(7/100/30)) ReadFile Incorrect function.
file_pread(5,14,buffer,118786(7/100/32)) ReadFile Incorrect function.
file_pread(5,3,buffer,118800(7/100/46)) ReadFile Incorrect function.
file_pread(5,3,buffer,118847(7/101/30)) ReadFile Incorrect function.
file_pread(5,8,buffer,118863(7/101/46)) ReadFile Incorrect function.
file_pread(5,11,buffer,118910(7/102/30)) ReadFile Incorrect function.
file_pread(5,2,buffer,120832(7/132/62)) ReadFile Incorrect function.
file_pread(5,14,buffer,120834(7/133/1)) ReadFile Incorrect function.
file_pread(5,3,buffer,120848(7/133/15)) ReadFile Incorrect function.
file_pread(5,3,buffer,120895(7/133/62)) ReadFile Incorrect function.
file_pread(5,8,buffer,120911(7/134/15)) ReadFile Incorrect function.
file_pread(5,11,buffer,120958(7/134/62)) ReadFile Incorrect function.
file_pread(5,2,buffer,122880(7/165/31)) ReadFile Incorrect function.
file_pread(5,14,buffer,122882(7/165/33)) ReadFile Incorrect function.
file_pread(5,3,buffer,122896(7/165/47)) ReadFile Incorrect function.
file_pread(5,3,buffer,122943(7/166/31)) ReadFile Incorrect function.
file_pread(5,8,buffer,122959(7/166/47)) ReadFile Incorrect function.
file_pread(5,11,buffer,123006(7/167/31)) ReadFile Incorrect function.
file_pread(5,2,buffer,124928(7/197/63)) ReadFile Incorrect function.
file_pread(5,14,buffer,124930(7/198/2)) ReadFile Incorrect function.
file_pread(5,3,buffer,124944(7/198/16)) ReadFile Incorrect function.
file_pread(5,3,buffer,124991(7/198/63)) ReadFile Incorrect function.
file_pread(5,8,buffer,125007(7/199/16)) ReadFile Incorrect function.
file_pread(5,11,buffer,125054(7/199/63)) ReadFile Incorrect function.
file_pread(5,2,buffer,126976(7/230/32)) ReadFile Incorrect function.
file_pread(5,14,buffer,126978(7/230/34)) ReadFile Incorrect function.
file_pread(5,3,buffer,126992(7/230/48)) ReadFile Incorrect function.
file_pread(5,3,buffer,127039(7/231/32)) ReadFile Incorrect function.
file_pread(5,8,buffer,127055(7/231/48)) ReadFile Incorrect function.
file_pread(5,11,buffer,127102(7/232/32)) ReadFile Incorrect function.
file_pread(5,2,buffer,129024(8/8/1)) ReadFile Incorrect function.
file_pread(5,16,buffer,128520(8/0/1)) ReadFile Incorrect function.
file_pread(5,3,buffer,128536(8/0/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,128583(8/1/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,128599(8/1/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,128646(8/2/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,130568(8/32/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,128586(8/1/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,128662(8/2/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,128709(8/3/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,130631(8/33/33)) ReadFile Incorrect function.
file_pread(5,14,buffer,129026(8/8/3)) ReadFile Incorrect function.
file_pread(5,3,buffer,129040(8/8/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,129087(8/9/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,129103(8/9/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,129150(8/10/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,131072(8/40/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,131074(8/40/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,131088(8/40/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,131135(8/41/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,131151(8/41/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,131198(8/42/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,133120(8/73/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,133122(8/73/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,133136(8/73/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,133183(8/74/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,133199(8/74/18)) ReadFile Incorrect function.
file_pread(5,14,buffer,153602(9/143/9)) ReadFile Incorrect function.
file_pread(5,3,buffer,153616(9/143/23)) ReadFile Incorrect function.
file_pread(5,3,buffer,153663(9/144/7)) ReadFile Incorrect function.
file_pread(5,8,buffer,153679(9/144/23)) ReadFile Incorrect function.
file_pread(5,11,buffer,153726(9/145/7)) ReadFile Incorrect function.
file_pread(5,2,buffer,155648(9/175/39)) ReadFile Incorrect function.
file_pread(5,14,buffer,155650(9/175/41)) ReadFile Incorrect function.
file_pread(5,3,buffer,155664(9/175/55)) ReadFile Incorrect function.
file_pread(5,3,buffer,155711(9/176/39)) ReadFile Incorrect function.
file_pread(5,8,buffer,155727(9/176/55)) ReadFile Incorrect function.
file_pread(5,11,buffer,155774(9/177/39)) ReadFile Incorrect function.
file_pread(5,2,buffer,157696(9/208/8)) ReadFile Incorrect function.
file_pread(5,14,buffer,157698(9/208/10)) ReadFile Incorrect function.
file_pread(5,3,buffer,157712(9/208/24)) ReadFile Incorrect function.
file_pread(5,3,buffer,157759(9/209/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,157775(9/209/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,157822(9/210/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,159744(9/240/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,159746(9/240/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,159760(9/240/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,159807(9/241/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,159823(9/241/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,159870(9/242/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,161792(10/18/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,160650(10/0/1)) ReadFile Incorrect function.
file_pread(5,3,buffer,160666(10/0/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,160713(10/1/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,160729(10/1/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,160776(10/2/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,162698(10/32/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,160716(10/1/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,160792(10/2/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,160839(10/3/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,162761(10/33/33)) ReadFile Incorrect function.
file_pread(5,14,buffer,161794(10/18/11)) ReadFile Incorrect function.
file_pread(5,3,buffer,161808(10/18/25)) ReadFile Incorrect function.
file_pread(5,3,buffer,161855(10/19/9)) ReadFile Incorrect function.
file_pread(5,8,buffer,161871(10/19/25)) ReadFile Incorrect function.
file_pread(5,11,buffer,161918(10/20/9)) ReadFile Incorrect function.
file_pread(5,2,buffer,163840(10/50/41)) ReadFile Incorrect function.
file_pread(5,14,buffer,163842(10/50/43)) ReadFile Incorrect function.
file_pread(5,3,buffer,163856(10/50/57)) ReadFile Incorrect function.
file_pread(5,3,buffer,163903(10/51/41)) ReadFile Incorrect function.
file_pread(5,8,buffer,163919(10/51/57)) ReadFile Incorrect function.
file_pread(5,11,buffer,163966(10/52/41)) ReadFile Incorrect function.
file_pread(5,2,buffer,165888(10/83/10)) ReadFile Incorrect function.
file_pread(5,14,buffer,165890(10/83/12)) ReadFile Incorrect function.
file_pread(5,3,buffer,165904(10/83/26)) ReadFile Incorrect function.
file_pread(5,3,buffer,165951(10/84/10)) ReadFile Incorrect function.
file_pread(5,8,buffer,165967(10/84/26)) ReadFile Incorrect function.
file_pread(5,11,buffer,166014(10/85/10)) ReadFile Incorrect function.
file_pread(5,2,buffer,167936(10/115/42)) ReadFile Incorrect function.
file_pread(5,14,buffer,167938(10/115/44)) ReadFile Incorrect function.
file_pread(5,3,buffer,167952(10/115/58)) ReadFile Incorrect function.
file_pread(5,3,buffer,167999(10/116/42)) ReadFile Incorrect function.
file_pread(5,8,buffer,168015(10/116/58)) ReadFile Incorrect function.
file_pread(5,11,buffer,168062(10/117/42)) ReadFile Incorrect function.
file_pread(5,2,buffer,169984(10/148/11)) ReadFile Incorrect function.
file_pread(5,14,buffer,169986(10/148/13)) ReadFile Incorrect function.
file_pread(5,3,buffer,170000(10/148/27)) ReadFile Incorrect function.
file_pread(5,3,buffer,170047(10/149/11)) ReadFile Incorrect function.
file_pread(5,8,buffer,170063(10/149/27)) ReadFile Incorrect function.
file_pread(5,11,buffer,170110(10/150/11)) ReadFile Incorrect function.
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
file_pread(5,1,buffer,6(0/0/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,132(0/2/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1071(0/17/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1087(0/17/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1134(0/18/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,3056(0/48/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,1074(0/17/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1150(0/18/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1197(0/19/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,3119(0/49/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2047(0/32/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2048(0/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,2049(0/32/34)) ReadFile Incorrect function.
file_pread(5,3,buffer,2064(0/32/49)) ReadFile Incorrect function.
file_pread(5,1,buffer,2113(0/33/35)) ReadFile Incorrect function.
file_pread(5,8,buffer,2127(0/33/49)) ReadFile Incorrect function.
file_pread(5,11,buffer,2174(0/34/33)) ReadFile Incorrect function.
file_pread(5,2,buffer,4096(0/65/2)) ReadFile Incorrect function.
file_pread(5,1,buffer,4095(0/65/1)) ReadFile Incorrect function.
file_pread(5,14,buffer,4098(0/65/4)) ReadFile Incorrect function.
file_pread(5,2,buffer,6144(0/97/34)) ReadFile Incorrect function.
file_pread(5,1,buffer,6143(0/97/33)) ReadFile Incorrect function.
file_pread(5,14,buffer,6146(0/97/36)) ReadFile Incorrect function.
file_pread(5,3,buffer,6160(0/97/50)) ReadFile Incorrect function.
file_pread(5,3,buffer,6207(0/98/34)) ReadFile Incorrect function.
file_pread(5,8,buffer,6223(0/98/50)) ReadFile Incorrect function.
file_pread(5,1,buffer,8191(0/130/2)) ReadFile Incorrect function.
file_pread(5,1,buffer,10239(0/162/34)) ReadFile Incorrect function.
file_pread(5,1,buffer,12287(0/195/3)) ReadFile Incorrect function.
file_pread(5,1,buffer,14335(0/227/35)) ReadFile Incorrect function.
file_pread(5,3,buffer,14352(0/227/52)) ReadFile Incorrect function.
file_pread(5,3,buffer,14399(0/228/36)) ReadFile Incorrect function.
file_pread(5,2,buffer,16384(1/5/5)) ReadFile Incorrect function.
file_pread(5,1,buffer,16064(0/254/63)) ReadFile Incorrect function.
file_pread(5,1,buffer,16065(1/0/1)) ReadFile Incorrect function.
file_pread(5,15,buffer,16066(1/0/2)) ReadFile Incorrect function.
file_pread(5,3,buffer,16081(1/0/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,16128(1/1/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,18113(1/32/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,16131(1/1/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,16207(1/2/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,16254(1/3/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,18176(1/33/33)) ReadFile Incorrect function.
file_pread(5,1,buffer,0(0/0/1)) ReadFile The request could not be performed because of an I/O device error.
Store new MBR code
file_pread(5,16,buffer,2048(0/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,2064(0/32/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2113(0/33/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,2127(0/33/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,2174(0/34/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,4096(0/65/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,4098(0/65/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,4112(0/65/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,4159(0/66/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,4175(0/66/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,4222(0/67/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,6144(0/97/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,6146(0/97/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,6160(0/97/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,6207(0/98/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,6223(0/98/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,6270(0/99/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,8192(0/130/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,8194(0/130/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,8208(0/130/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,8255(0/131/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,8271(0/131/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,8318(0/132/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,10240(0/162/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,10242(0/162/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,10256(0/162/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,10303(0/163/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,10319(0/163/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,10366(0/164/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,12288(0/195/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,12290(0/195/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,12304(0/195/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,12351(0/196/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,12367(0/196/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,12414(0/197/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,14336(0/227/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,14338(0/227/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,14352(0/227/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,14399(0/228/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,14415(0/228/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,14462(0/229/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,16384(1/5/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,15120(0/240/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,15136(0/240/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,15183(0/241/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,15199(0/241/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,15246(0/242/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,17168(1/17/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,15186(0/241/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,15262(0/242/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,15309(0/243/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,17231(1/18/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,16065(1/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16081(1/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16128(1/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16144(1/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16191(1/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,16131(1/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953503999(121599/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953504000(121600/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,1953504001(121600/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953504015(121600/0/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953504062(121600/0/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1953504078(121600/1/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1953504125(121600/1/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,1953506047(121600/32/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953520064(121600/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,2049(0/32/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,4095(0/65/1)) ReadFile The request could not be performed because of an I/O device error.
interface_load
file_pread(5,1,buffer,0(0/0/1)) ReadFile Incorrect function.
Store new MBR code
